device not detected
Old 28th Jul 2006, 4:50 am
Default device not detected
help me please, my player is dead, i follow the best step solution, after all, when i upgrade my firmware, device not detected, but when i browse the drive where my player is my pc recognized it "accessible" please help me, i really need it badly, thank you so much...
Old 28th Jul 2006, 6:14 am
badzlibid, Your player is possibly being recognised as a USB Device instead of Adfu device. Try disconnecting your player from your PC, short the chip and then connect it to a different USB Port preferably one you have not used the player on before.
Old 8th Aug 2006, 2:14 am
Default Re: device not detected
i followed ur advice, but still didn't work... please
Old 8th Aug 2006, 2:57 am
So what happens after you tried to follow the steps mentioend by tadad?
What other messages are you getting now?
Have you also tried:
1. Plugging your player into another computer?
2. Using a different USB cable instead?
3. Plugging your USB cable into ANOTHER USB port on the computer instead? Try all of them to see if it has any result.
Look forward to hearing from you what happens when you try those.....
Old 8th Aug 2006, 4:48 am
sir, i already did that, still the same, when i am finish this step from the recovery guide: Turn the player off and then back on. Wait about 30 seconds till it boots now open the MP3 Upgrade Tool again. If it indicates that there is no device connected see if you can access your player through Explorer. If you can not you may need to format it with Windows. I have found that both FAT and FAT32 work on newer models but suggest you use FAT to avoid any problems. Once formatted the MP3 Upgrade Tool should have no problems. Now you can upload your backup dump.bin. Your player should now reboot and be fully recovered.
still no other good condition, i don't have dump.bin "backup" my mp4 player is sundisk... hope u can help me
Player detected as ADFU device and not allocated as F:drive vhone601 Dead Players 7 21st Mar 2009 4:58 pm
Detected as ADFU device but shows hour glass iNobody_bd Dead Players 1 4th May 2008 6:23 am
Device not detected in Xp laptop and when Driver Cd is used kalyan.naga Dead Players 1 5th Feb 2008 5:53 am
[solved] Device Switching Failed, reconnect device please! Spawn_20240 General Discussion 5 2nd Aug 2006 6:44 pm
[solved] Device not being detected by the s1fwx.exe tool tboogie Support and How To 10 14th Jun 2006 1:51 pm
