Problem trying to repair firmware
Old 28th Jul 2006, 3:15 pm
Default Problem trying to repair firmware
ok if i upgrade the mp3 player with the backup dump, the mp3 player displayed a waiting screen, after a few hours still in this mode.., and the computer reconized it like a ADFU divice, when i try to repair the dump file xtrated with s1fw extract tool, it gave an error, and tried the list tool and said this[
s1fwx v3.0 - copyright (c) 2005 wiRe (http://www.s1mp3.de/)
filename = 'dump.bin'
filetype = afi
md5 = 3A5B8F55605F56EC562713CA70C62F60
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 3.5.35
date = 00/00/0000
| BRECF644.BIN | | 16kb | | F644 | | B | | 1A838DEF |
| FWSCF644.BIN | | 11.5kb | | F644 | | F | | 5A419386 |
| ADFUF644.AP | | 10.5kb | | F644 | | U | | 4178AEB0 |
| FWIMAGE.FW | | 2.92mb | | | | I | | 1780E786 | <-invalid checksum
| SYSINFO.BIN | | 192bytes | | | | | | 1DA00FA9 |
filetype = fw
md5 = 08F943DCBECB29DDE9493DFD917D2B44
---[ info:fw ]-----------------------------------------------------------------
file id = 0x0FF0AA55
vendor id = 0x10D6
product id = 0x1100
version = 3.5.35
date = 11/09/2005
info = 'SDK-ITEM/ACTIONSGongee.ZH'
device name = 'S1 Mp3 Player'
usb attr = 'GENERIC'
usb ident = 'MP3'
usb rev = '1.00'
rtc rate = 0x3B6
display contrast = 11
light time = 3
standby time = 30
sleep time = 0
language = english
replay mode = 0x00
online mode = 0x00
battery type = 1.5V alkaline
radio/fm support = yes
+---filename---+ +---size---+ +--chksum--+
| SYSCFG.SYS | | 14kb | | 008E244D |
| SYSBNKA.SYS | | 23.5kb | | E58EFC6A |
| SYSBNKB.SYS | | 18kb | | F345D529 |
| ASCII.BIN | | 6kb | | 1B4869CE |
| FONT_GB.$$$ | | 238kb | | 10763F2D |
| FONT_B5.$$$ | | 461.5kb | | D22E11D5 |
| FTBL_GB.$$$ | | 128kb | | 15838D9E |
| FTBL_B5.$$$ | | 128kb | | B668C06A |
| FONT_KR.$$$ | | 264.5kb | | F8E28BB1 |
| FONT_JP.$$$ | | 282kb | | FBEAD101 |
| FTBL_KR.$$$ | | 128kb | | 707CBF05 |
| FTBL_JP.$$$ | | 128kb | | 67B14D2A |
| DSCDSPSX.DSP | | 32kb | | B53C92D4 |
| AEAWB.DSP | | 15.5kb | | 699DEAAD |
| DSCDSP65.DSP | | 32kb | | DDECAD21 |
| DSCDSPTS.DSP | | 32kb | | 0FD1DBB1 |
| DSCDSP.DSP | | 20kb | | 5B382EDC |
| PCMDEC.DSP | | 6.5kb | | 10C9A950 |
| ADPCMENC.DSP | | 5kb | | 0387E7A3 |
| AG8DEC.DSP | | 20kb | | 5073404E |
| AG8ENC.DSP | | 32kb | | 9BCD06B7 |
| WMADEC.DSP | | 97.5kb | | 7795C313 |
| MP3DEC.DSP | | 69.5kb | | CA7DF938 |
| MP3ENC.DSP | | 36.5kb | | 45A2920F |
| ADENCM.DSP | | 6.5kb | | D2C08C56 |
| OGGDEC.DSP | | 81.5kb | | DDEA2E29 |
| WMATABLE.BIN | | 13.5kb | | 9993E9B4 |
| OGGTABLE.BIN | | 13.5kb | | C69734B6 |
| ADFUS.BIN | | 9kb | | 21D089D3 |
| UD_FF644.DRV | | 4.5kb | | D599E3C4 |
| UD_FF641.DRV | | 4.5kb | | FB719DFD |
| UD_FF321.DRV | | 4.5kb | | 47D70C9D |
| UD_SF644.DRV | | 4.5kb | | 0E541850 |
| UD_SF641.DRV | | 4.5kb | | C267432E |
| UD_SF321.DRV | | 4.5kb | | F63747F7 |
| UD_SDMMC.DRV | | 4.5kb | | 38A947BF |
| FS_FAT16.DRV | | 51.5kb | | 18EF61AB |
| FS_FAT32.DRV | | 51.5kb | | 66A2FF7C |
| VM_NANF.DRV | | 3.5kb | | B2B72E2B |
| SD_FF644.DRV | | 3.5kb | | B41F3A16 |
| SD_FF641.DRV | | 3.5kb | | E1B6CEC7 |
| SD_FF321.DRV | | 3.5kb | | 83CB08ED |
| UI_S0724.DRV | | 14.5kb | | 4912DC94 |
| UI_T0724.DRV | | 14.5kb | | 6662D830 |
| UI_L0724.DRV | | 14.5kb | | 0B4F55AB |
| UI_K0724.DRV | | 14.5kb | | 6B0735F4 |
| UI_J0724.DRV | | 14.5kb | | 7C71D28F |
| KY_HARD.DRV | | 1.5kb | | 506CCBE9 |
| UI30.RES | | 75.5kb | | D72F8523 |
| LOGO.RES | | 7.5kb | | 635EACBC |
| END.RES | | 3.5kb | | AEEDFC51 |
| KCFG.AP | | 6kb | | 756F8B6D |
| MAIN.AP | | 10kb | | 22E3E401 |
| STANDBY.AP | | 7.5kb | | D2F9F5FE |
| USBDISK.AP | | 15.5kb | | BA3E48DC |
| MUSIC.AP | | 82.5kb | | 95D7A0E3 |
| RECORD.AP | | 30kb | | B9C4CA3A |
| VOICE.AP | | 39.5kb | | 4B1ED835 |
| SETTING.AP | | 18kb | | 7C263F0E |
| FMRADIO.AP | | 14.5kb | | 2B9CE00D |
| TESTER.AP | | 8.5kb | | ECE9B8F6 |
| M-RECORD.AP | | 34.5kb | | 8DD1613A |
| CAMERA.AP | | 26kb | | 45297D6B |
| FMRECORD.AP | | 34kb | | D7651BAB |
can someone help me with this invalid checksum ? what that means?
also here is the dump file(RAR FILE),
DIRECT LINK
or
FOLDER the pass is domi
Old 28th Jul 2006, 7:48 pm
domi,
Where did you get this firmware from?
The checksum error means that the file is not being read at the proper size. Your FWIMAGE.FW contains all the files listed in the long list but it is to small 2.92MB it should be around the 6 or 7 MB mark and there appear to be some files missing from it. Nothing you can do to fix it sorry.
If your player is recognised as an ADFU device it is in recovery mode and you need to use a Full Version Firmware, your player will not accept a dump while in recovery mode. There are some full versions HERE
I suggest you read the DEAD PLAYER RECOVERY GUIDE HERE and scroll down to the section regarding ADFU install and then proceed on from there,
Old 29th Jul 2006, 7:19 am
Originally Posted by tadad1";p=&quot View Post
domi,
i got it from s1fwx extract program,
if i found a mp3 player like mines, can i repair this xtracting a full firmware ? but wich is better program to do this ? i was using the s1fwx tools, but i think that this program do not xtract a full firmware... i already read the recover guide... did everything, and i didnt found the full firmware for my mp3 player here
thanks for ur help tadad1, ill be around, if i found a solution ill post it here...
Old 29th Jul 2006, 7:24 am
domi,
Are you using s1fwx to extract the firmware from a dead player?
If the firmware you uploaded from a working player?
It is not possible to extract a Full Firmware.
Old 29th Jul 2006, 7:27 am
i extracted that dump file when the player was working...
wit this tool can i get a full firmware from a working one ?
Old 29th Jul 2006, 7:36 am
domi,
There are no programs to extract a Full Firmware. It is only possible to extract dump files.
You could use s1fwx to extract from another player if it was the same player it may work. But you would need to load a full version firmware before you could load a dump if your player is in Recovery Mode as an ADFU Device. There are some Full Firmware HERE Even if the Full Firmware does not fix your player 100% you will then de able to load dump files.
Old 29th Jul 2006, 7:43 am
domi,
ohh i understood, load a full firmw... to allow the player upload the dump file extracted from a good one, thanks, ill find a good one to do this.. but it will take me a long time.. thanks a lot tadad1 for ur time and everything to try help me, thanks again
Old 31st Jul 2006, 5:05 pm
if any one have this fullfirmware plz contac me:
domi994[at]gmail[dot]com
help how to repair this problem tarunvishal Dead Players 2 19th Jul 2007 4:25 am
Memory or Firmware repair PLZ JayD* Dead Players 19 27th Feb 2007 5:27 pm
Repair firm 9.0.43 problem sanaken Mods and Themes 8 18th Dec 2006 6:55 am
Firmware repair error ufo12 Support and How To 2 12th Nov 2006 6:09 pm
Can't repair my MP4 firmware with s1fwx 3.0 Bayu Support and How To 3 15th Jul 2006 12:48 am
