Volume button not fully functioning
Old 4th Aug 2006, 6:46 pm
Default Volume button not fully functioning
tatad1,
how do i fix my mp4...? i already fixed the firmware but the volume button is not functioning... but if you press the volume button when you are playing mp3, the volume decreases... how do i fix it? pls help me. tnx..
Old 4th Aug 2006, 7:22 pm
ramlef, What sort of player do you have?
When you say you have fixed the firmware are you using a different firmware from your players original one?
If so it may have a different button configuration than your player. Another thing you could try is extracting the firmware, repairing it then reloading it.
Old 6th Aug 2006, 6:21 pm
Default Re: Volume button not fully functioning
tatad1,
i have a ipod nano look mp4 with a size of 512MB. I try to upgrade my player but i'm failed to upgrade it because i got a worng firmware. But I already got a correct firmware. after i install it, it works. But when i use it, I press the volume. The volume menu didn't appear. But when I press the volume button, the volume decreases... do you have a firmware of ipod nano look mp4 with a firmware of 3.5.37?
Old 6th Aug 2006, 6:26 pm
I have a ipod nano look mp4 with a size of 512MB like in the picture in this link..
http://www.mympxplayer.com/album_showpage.php?pic_id=88
Old 6th Aug 2006, 6:41 pm
ramlef, All the firmware I have are already in the firmware download section. I would say the firmware you have loaded is for a player that has nVol+ amd Vol- buttons. You could try loading the firmware into Waterlily and going to the System Keys tab and setting the keys as follows:
Key1=Play
Key2=Menu
Key3=Prev
Key4=Next
Key5=Null
Key6=Null
Key7=Record
Key8=Null
Key9=Null
Key10=Null
Key11=Null
Key12=Null
Hold=Off
This is how the buttons are configured on my Nano clones.
If that does not work then you will have to keep looking for firmware that suits your player.
You can download Waterliliy HERE
Old 6th Aug 2006, 8:23 pm
tatad1,
I have change the system settings. I have followed the settings you have given to me but the volume button becomes pause button. the vol button of my player is have a volume menu when you press it while playing a mp3. when the volume menu appear, the next button is the vol+ and the prev button is the vol-... can u give me another setting??
Old 6th Aug 2006, 9:58 pm
my player is the same like the picture in this URL..
http://www.mympxplayer.com/album_showpage.php?pic_id=91
Old 6th Aug 2006, 10:02 pm
tatad1,
some additional question... can u give the functions of key1-12. example: Key1 - Play....
Old 6th Aug 2006, 10:50 pm
ramlef, The keys that I gave you are how my nano clone appears in Waterlily and it also has the popup volume menu slider when you push the vol button. You will have to experiment with other settings or try another firmware.
Old 7th Aug 2006, 12:55 am
tadad1,
can u give me the firmware that is running in nano clone mp4 that is 512MB and a screen of 1.8". before i attemp to upgrade it, the fiirmware was 3.5.37.. do you have a firmware like in your nano clone player? because i forgot to backup it. can you give me? thank you in advance.
[solved] no volume button! stellaluna Support and How To 4 18th Dec 2009 11:02 pm
Touch screen not functioning catus Dead Players 5 25th Feb 2009 11:39 am
Volume up button does not work silence Support and How To 3 6th Dec 2008 5:21 pm
left button works same as right button TUANAS Support and How To 4 16th Oct 2007 8:48 am
Help.. volume button doesn't work h8isgr8 Support and How To 8 1st Oct 2006 3:56 pm
