[solved] BIG Problem
Old 8th Aug 2006, 3:36 pm
Default [solved] BIG Problem
after installing a mooded bin file from this site but cant remember which it was...
my mp4 player is a 4gb ipod copy with a MP4 logon in the front.
the problem is the player is constantly bluescreened and when I connect it my computer shuts down with a bluescreen where plug and play device is the failing driveror somethiing like that.
I cant change the firware now anyways.. is there something I can do to reset the player or maybe format it...
I can connect it to an computer because it shuts it down.
help me please
Old 8th Aug 2006, 4:41 pm
lekie, Try following the DEAD PLAYER RECOVERY GUIDE HERE it is the only way I know that will get your player to a state where you can try some other firmware to recover your player.
Old 8th Aug 2006, 10:46 pm
Default Re: BIG Problem
OKI then
I´ll try it and keep ya uppdated on how it goes
thanx
Old 9th Aug 2006, 6:40 am
Problem solved
And on the first try also..
but I can confess I didnt think it would work when my computer shut down all the time..
and no I´m looking for a new firmware for my player
but thats a new thread
thanx for the help
[solved] Problem with AMV Convertor 4.09 tom164 Support and How To 3 21st May 2007 5:02 am
[solved] Playlist problem Ricochet Support and How To 1 21st Apr 2007 8:01 am
{solved} amv video problem theskems Video related 21 14th Jul 2006 10:16 am
( Solved )Pocketdivxencoder problem Simonski Video related 2 14th Jul 2006 5:08 am
Plz help me -= STARTING =- problem [SolveD] rockerenator Dead Players 10 6th Jul 2006 5:21 am
