-   -   how to copy firmware and load to other player (http://mympx.org/forum/dead-players/34117-how-copy-firmware-load-other-player.html)
kryss 4th Sep 2006 5:11 am
please help me>> i have an old player and upgraded its firmware but unfortunately i cant see any menu anymore in the player but i can still use it.. i bought another one... Can i copy the firmware of my new player and placed it on my old player? Can this fix the problem? please let me know how to do it to recover my old player>> the both player are the same.. thank you very much>>
kuldeep.com 4th Sep 2006 7:53 am
i have 2gb player ver ACT_V3.5.35 I upgrade my player but after upgrading the player the player screen get blue and my player is dead. how can i start my player
tadad1 4th Sep 2006 5:31 pm
Re: how to copy firmware and load to other player
kryss, You can certainly try extracting the firmware from your new player and loading it to your old player, you would need to download s1fwx HERE and there is a guide to using it HERE.
kryss 5th Sep 2006 2:35 am
thanThank you very much for your info, hope that i can follow the guide and successfully recover my old player.. tnx..
kryss 9th Sep 2006 9:17 am
i would like to ask this question, everytime that i use the upgrading tool why is it shows that im still using the 3.5.35 version and i already upgraded it to 3.5.37, i am confused because if i am going to extract my firmware it is stated that it is v3.5.35 still.. and one thing more it also shows that it is not supported with FM but previously it has..
tadad1 9th Sep 2006 6:09 pm
kryss, You may find that even though it says no FM that it is there anyway. What version firmware does your player show in the Settings menu?
