please, please help me, double problem
Old 20th Sep 2006, 5:39 am
Default please, please help me, double problem
hello, I received my mp4 player ( style ipod ), and I wanted to upgrade the firmware. It didn't work, I only had a blue screen. I dried a lot of firmware, and, the 6 one, made my mp4 player undectable. My computeur doesn't detect my mp3 ( not as a mp4, not as an hard disk ). I tried with another computer, it's the same problem!
I don't know what to do, I can't have lost my money like that.
thanks
Old 20th Sep 2006, 6:10 am
mimik,
If that is the case then the only option you have is to try the Dead Player Recovery Guide HERE. If you have backed up your original firmware you have a pretty good chance of recovering your player, if not your chances are not so good as you will have to try random firmware till you find one to suit your player.
Old 20th Sep 2006, 8:42 am
I tried, my computer does'nt detect it anymore ... I ll try again,
Old 20th Sep 2006, 10:21 am
mimik, Are you shorting the memory chip as outlined in the Dead Player recovery Guide?
auxiliary cable (double ended 3.5mm) for use in car Lorne General Discussion 3 14th Jan 2009 1:57 am
