firmware brightness help
Old 23rd Sep 2006, 1:24 pm
Default firmware brightness help
my problem is "my player was dead...i up a new firmware and my brightness is out...my screen is not good , the brightness is not good , i don't know if you understand me i don't have a good english... so i search a firmware to have the good brightness..
i have "ATJ2085W" "SAMSUNG 622
K9WAG08U1M"
Old 23rd Sep 2006, 9:09 pm
if you have an mp4 you can try going to its setting and somewhere in there there's a brightness option. hope this helps.
Old 24th Sep 2006, 3:20 am
Default Re: firmware brightness help
i know , i've changed brightness in options but it's not good :s
Old 24th Sep 2006, 7:18 am
capa57, I am not sure if your screen is to bright or to dark. Try loading your firmware into Firmware Modifier HERE
It has a slider for adjusting the contrast up or down. I have used it successfully to make a screen brighter. Do not try and adjust the Radio setting as it will remove some features from your firmware.
Old 24th Sep 2006, 8:44 am
he's to bright !!(white)
my brightness is always not good , when i put brightness at 31 ...i see nothing , and when i put at 0 i see a little
i need to change firmware or put brightness at -15 or -30 but i can't put under 0 ...
Old 27th Sep 2006, 10:09 pm
help me
Old 27th Sep 2006, 10:41 pm
capa57,
I do not know of any way to change the setting down as far as you need within the firmware. I would say that the firmware you are using is for a different LCD type. Your only option really is to try other firmware to find one that is more compatible.
Not allowing me to adjust exposure/brightness loog Support and How To 3 19th Dec 2007 10:17 pm
Help with mp4 brightness... falchi Support and How To 2 26th Aug 2007 6:06 pm
brightness level sylar_jones Support and How To 3 19th Aug 2007 11:16 am
Battery life/LCD brightness Galaxieman Support and How To 5 17th Mar 2007 3:57 am
