27th Sep 2006, 4:55 am
Re: Problem Connecting to Computer
jonjon, it seems that your two problems are inter-related. I have a feeling that maybe your cable is faulty, or usb port is faulty, or your player's usb socket is faulty.
Try it on another usb port and on another computer to see if the problem persists.
Generally when you connect your player to the computer, your player should show the screen of the player connected to the computer, and probably after a couple of secs would black out. But if you click any buttons, it would would show the same screen again.
Is the blue screen with the arrow or hourglass?
