Need firmware: PMA300_010 - SRX - 3.5.37
Old 30th Nov 2006, 5:47 am
I ALSO WANNA SAME FIRMWARE. IF U HAVE PLZ SEND ME ALSO...
CORE: PMA300_010
DATE: 2006-03-15
FW: SRX - 3.5.37
DATE: 2006-03-24
MY SCREEN IS 1.5
Old 30th Nov 2006, 5:57 am
anurajnr,
http://www.mympxplayer.org/pma300010...ump-df373.html
Old 30th Mar 2007, 2:47 am
CORE: PMA300_010
DATE: 2006-03-15
FW: SRX - 3.5.37
DATE: 2006-03-24
MY SCREEN IS 1.5
How can I change the firmware??
Old 2nd Apr 2007, 9:25 pm
Default Re: Need firmware: PMA300_010 - SRX - 3.5.37
Hi,
Same problem with me also, i have got a player with these config.
Core - PMA300_010 Dt 2006-03-15
FW - SRX-3.5.37 Dt 2006-03-24
Screen - 1.5"
If anyone having any solution please help me out.
Can mail me at kumar_raj78@rediffmail.com
Thanx,
CORE: PMA300_010
DATE: 2006-03-15
FW: SRX - 3.5.37
DATE: 2006-03-24
MY SCREEN IS 1.5
[/quote]
Old 8th Jul 2007, 10:29 pm
Originally Posted by tadad1";p=&quot View Post
it doesnt help me
  #16 (permalink)
Old 9th Jul 2007, 12:04 am
Why the hell does everyone want to change the firmware? Whats wrong with it the way it is?
If it is ALREADY WORKING you DONT CHANGE THE FIRMWARE
[hr:43af44b395]
  #17 (permalink)
Old 27th Dec 2008, 9:22 pm
Default firmware for PMA300_010 3.5.37
Hi guys,
Pls help me. I'd like to upgrade my player's firmware.
Here's the firmware version info:
PMA 300_010
2006/05/25
3.5.37
2006/07/20
I hate so many things about it right now.
1. It says "Low Power" and just dies when I unplug it from my laptop. It can't survive on its own.
2. When I'm playing Music, I can't navigate to the Menu without ending the music that I'm listening to. So I have to start all over again when I'm done going thru whatever it was I wanted to check in the menu.
3. The lights go out after like 3 sec. I can't find the settings to make the LCD lights stay on longer! Is there even an option to do this??
4. It's so difficult to use the buttons. I don't even know if pressing the MENU key is just for "back" and "enter" or also for Power On. The play button can also act as power on I think. I'm a bit confused with this.
5. It won't register as a new "drive" when I plug it in my laptop. The reason why I want to see the contents is because I want to copy my songs and other files so I can upgrade the firmware. All files will be deleted when I upgrade right?
Thanks!
Hope you can send the firmware. I'm hoping upgrading will solve some of my problems with this player. Arrrgh!
DJ
