-   -   HELP HELP another blue scren but impossbile ti fix i'm sure (http://mympx.org/forum/dead-players/34498-help-help-another-blue-scren-but-impossbile-ti-fix-im-sure.html)
memaxt 5th Oct 2006 3:33 pm
Hiya everyone!
since once agen another person with a blue screen!
I've tried the dead Firmware guide hasnt really helped
recently i tried to update my 1GB White nano Fake 3.3.37 to sumfin else better...i dont know y but the seems to be the most recent one!..i try to uploads a new dump file but still a blue screen tried many dump firmware file but none seem to help!
Samsung 625 K9K8C08UOA ATJ2085W<------cant find anythin for that can anyone help?
Also have the oringal cd but its all in chinese and all the firmware files dont seem to work either... i have no idea what to do or where to get the correct file..please help!
tadad1 5th Oct 2006 4:16 pm
memaxt, If you have firmware on your CD copy it to your PC and remove any Chinese text or symbols by remaning the file dump.bin and then try loading it to your player.
memaxt 5th Oct 2006 4:22 pm
Re: HELP HELP another blue scren but impossbile ti fix i'm
i've tried that..i get the message - Read or write device information failed.. PLease exit the program and check if the device is connecting (its connected!)
or one says invalid firmware version<---or sothing simalar..the cd conrains folders caled 1.2 , 1.5 , 1.8, 2.5
i got in the 1.5 folder and it contains subfolders called:
HS-403(633)
HS-473
loads of different folders that contain a FW file..but no luck any ideas?
