MP4 Player Major Screen Problem
Old 5th Oct 2006, 9:20 pm
Default MP4 Player Major Screen Problem
PLEASE HELP
the player still turns on....but when i try to go to other options in all the different menus(main menu, music menu)...the screen goes crazy.....and then im left with a black screen...then i have to do a hard restart inorder to fix the screen....but then it happens again...whats wrong with it and what should i do??
this is the mp4 player i have
Old 5th Oct 2006, 9:56 pm
sorjaion,
Has the player ever worked properly?
Have you upgraded the firmware recently?
Try extracting the firmware with s1fwx repair it then load it back to your player then format your player in Fat format. You can downloas s1fwx HERE and there is a guide to using it HERE
Old 5th Oct 2006, 10:12 pm
Default Re: MP4 Player Major Screen Problem
yea..i was workin' properli fo' a while...and then the screen started havin' some problems....i made a backup dump.bin before i did anythin'....i tried formattin' the player and then upgradin' it back to the old dump.bin...but the same thing happens.
when i go to different options, the display get all distorted and then it jus' turn into a black screen.
Old 5th Oct 2006, 10:15 pm
could it be that sth is lose inside the player...coz when i shake it...i hear somethin' lose inside
Old 5th Oct 2006, 10:42 pm
sorjaion, Could very well be a loose connection or a short in the buttons. If it is still under warrent y you should contact the seller if not then I suggest opening the player and see if you can locate any problems.
Old 7th Oct 2006, 1:39 am
the sth lose turn out to be jus' the cables connected to the battery....so i think its the firmware's problem..what should i do??
Old 12th Oct 2006, 4:41 pm
its still not workin'...if i dont move ...the screen is fine.....but the screen turns black/blue as soon as i try to move to another option
do u know which firmware i use for
chip ATJ2085W
samsung 628 k9wag08u1a-pcb0
RK27SDK MAJOR VERSION ID 2.2 Hardware id 080722 32GB BPS1 General Discussion 3 9th Nov 2009 10:54 am
32g touchscreen RK27XX MAJOR ISSUES, PLEASE HELP Jodi-Lena Support and How To 2 23rd Oct 2009 4:36 am
mp4 screen problem kolo General Discussion 0 15th Oct 2006 3:53 pm
screen problem with new FW m4c General Discussion 1 20th Sep 2006 10:00 am
Fake Ipod 1.5 Screen - Problem with Firmware (Blue Screen) skaterfou Dead Players 16 3rd Jun 2006 6:59 am
