-   -   usb cable (http://mympx.org/forum/dead-players/34510-usb-cable.html)
pigdogboy 6th Oct 2006 7:48 am
usb cable
I have a broken my usb cable. The actual cable has come away from the connector that plugs into the bottom of the chiPod (weak solder I guess). I am quite capable of resoldering the cable together, i just don't want to have to connect up the cable and use trial and error to get the right connection. Could one of you kind people have a look at one of yours and post either a photo or a description of which wire goes where. If anything like mine the plastic casing on the end of the lead falls off rather easily to see the connections. My actual model is exactly the same as the chiPod in the dead player recovery guide.
Thanks in advance :D
