need firmware ATJ2085I
Old 6th Oct 2006, 11:52 pm
Default need firmware ATJ2085I
hello people, i'm benji from mexico and like most of all i have a problem finding my firmware, i dunno if it's a very rare firmware or what cuz i can't find it, pleeeeease someone help me find the ATJ2085I firmware i need it i can't live without my music!!
Old 7th Oct 2006, 12:19 am
Default Re: need firmware ATJ2085I
benfromhell , is your player currently reconisged by your computer? If not, you will need to follow the Dead Player Recovery steps HERE.
If your player is still reconigsed by your computer, then you will need to try random firmwares in the downloads section, and hopefully one works for your player.
Old 7th Oct 2006, 12:21 am
i can makeir work by touching the pins and stuff but now my head hurts cuz i had all day looking for the firmware but i can't find it, that's the main problem
Old 7th Oct 2006, 12:27 am
i guess my problem was not to make a backup, i had problems cuz the extract.bat file didn't wanted to open saying "another program is currently using the file" and the hole backup things didn't worked for me, maybe some day i will find my beloved firmware, i'll be waiting here hahaha
Old 7th Oct 2006, 12:45 am
There is no fixed location for shorting of the pins, everything is random in the Dead Player Recovery.
Once you get the player detected by your computer, you will be in recovery mode, and you need to upload a new Full Firmware and get it detected as a USB drive.
Now the player can be detected by the Mp3 Upgrade Tool, and now you need to upload a random dump firmware to try to get your player working.
Both these firmwares can be found in the downloads section, they may or may not work.
But if you are patient to try every different combination of Full and Dump firmwares, you have a better chance of recovering your player.
Good luck
1.5 Screen 512 mb atj2085i chip.bin camaro96a Dead Players 3 13th Feb 2007 2:19 pm
looking for ATJ2085I & samsung 625-k9f408u0a camaro96a Dead Players 0 9th Jan 2007 1:34 am
sam sung 625 / K9F4G08U0A 512MB /ATJ2085I camaro96a Dead Players 0 4th Dec 2006 1:10 pm
