blue screen after firmware upgrade
Old 9th Oct 2006, 8:29 am
Default blue screen after firmware upgrade
Hi,
I have a hacked 4gb player as seen Web Page Name I found it was hacked when I did a format (FAT) with HP tools and the new memory size became 1961mb (2mb).
I them uploaded FW from cd which came with the player,..see attached pic but all I get now is the blue screen when I power on the player...what next ?
Rgds to all.[img]Click the image to open in full size.[/img]
Old 9th Oct 2006, 8:37 am
Default Re: HELP!! blue screen
lenney , why did you upload the firmware in? Did the player give any problems?
Most firmwares in the CDs that came along with the players are mass-produced firmwares which usually do not match your player and flashing them in would likely kill your player. Which i think happened to your player this time.
Is your player currently still detectable by your computer? If you had a backup firmware that you extracted from your player earlier on, you can try to flash it back. If not, you need to try random firmwares in the downloads section to attempt to revive your player.
Old 9th Oct 2006, 12:54 pm
Default Re: blue screen after firmware upgrade
Yes, the player is seen in windows, I have another player which I extracted & repaired the FW from using s1fwx v2.6 & then uploaded to problem player but problem remains,...blue screen !!
Rgds
Old 9th Oct 2006, 6:08 pm
lenney , if your player with the blue is able to be detected by the MP3 Upgrade Tool, you will need to try various firmwares to your player in the downloads section. There's no fixed firmware to solve your problem, just need to keep trying random firmwares.
Good Luck.
Old 10th Oct 2006, 2:30 am
Good Luck.
alas I was dreading that, oh well here go's
[solved] my player displays blue screen after upgrade wiredcool24 Dead Players 14 26th Oct 2006 2:12 am
after upgrade only blue screen foxone Dead Players 8 8th Aug 2006 4:54 pm
[solved] Blue screen after firmware upgrade Djgazi Dead Players 4 27th Jun 2006 8:21 pm
blue screen after firmare upgrade donzai Dead Players 6 31st May 2006 8:02 am
Blue screen after Firmare upgrade!!!! Support and How To 1 27th May 2006 2:46 am
