Dead Player wont power up after fw upgrade
Old 9th Oct 2006, 11:08 am
Default Dead Player wont power up after fw upgrade
To start with I had the same problem as many others here have had with the Players. I was unable to upgrade the firmware and it wouldnt recognise my device and thanks to Tadad his advice helped me overcome that.
Now I have upgraded with version 3.2.xxx firmware when I know I should have used 3.5.37 fw and after I upgraded the screen flashed for a while and now its blank. The screen now doesnt power up and I cant do anything to power it back up. I tried shorting the chip out with tweezers but it is no longer recognised.
What can I do to solve this?
Old 9th Oct 2006, 4:43 pm
zacspeed, "ok1" found that shorting the cpu chip fixed the problem for him. I have not tried it myself. Also connect to another USB port, one you have not used the player on before if possible.
Also If you have shorted your player before and it has been recognised as an adfu device and your player has gone to recovery mode Windows may remember the device and give you no notification of connection so after shorting try the upgrade tool to see if it detects the device.
Old 9th Oct 2006, 8:33 pm
Default Re: Dead Player wont power up after fw upgrade
Hi Tadad,
Thanks for your help,
I've tried all those suggestions. It just simply isnt responsive anymore.
Ive tried varying USB slots and shorting out different areas of the board.
My pc recognises another player that is functional but not mine.
Im at a loss now.
It's like its dead now as i get no response, no display picture but its only been doing it since I tried upgrading with 3.2.xx firmware.
Any ideas?
Many thanks
Old 9th Oct 2006, 9:05 pm
zacspeed,
If it is cactus, I doubt if it is due to the firmware it is more likely a component failure. But some times they can be stubborn to reset. The other thing that I have done on occassion is to connect the tweezers across the chip from side to side and drag them across all the pins. I doubt if this is a good thing to do but I have not killed a chip yet but do this at your own risk.
Old 9th Oct 2006, 9:31 pm
Yeah ta,
Im starting to think theres nothing else that can be done.
Im sure its not cactus as it happened immediately after the firmware upgrade to 3.2 when i should have only used 3.5
I'll keep persisting, but the lesson learnt is if it aint broke dont fix it.
Just was hoping to get the flashier features as some other 1s did.
oh well.
thanks again
Player hang on power startup mobileconcern Firmware 3 3rd Sep 2008 8:29 am
sony fake mp4 dead... no power..how to revive AT2085H quedee99 Dead Players 0 26th Jul 2008 7:28 pm
Looking for firmware for Power Max ANYKA MP4 player johncruez Support and How To 0 25th May 2008 2:40 am
portable mp3-mp4 game player no power corleon Dead Players 0 24th Dec 2007 3:00 am
Dead M Power m11 misiodab Dead Players 1 12th May 2007 9:20 am
