[solved] About connection between the pins
Old 9th Oct 2006, 10:18 pm
Default [solved] About connection between the pins
About connection between the pins.
"Using the tweezers or other metal item gently make a connection between the pins on one side of the chip. I have found this can be quite random you may also have to do it a few times"
Try to make a connection between the pins 41-44 or 32-29 (see picture).
<img>
I think, that other is useless.
If you don't agree - post down here.
Old 9th Oct 2006, 10:25 pm
Default Re: [solved] About connection between the pins
The picture is http://www.Eqwelibrium.narod.ru/chip.png
mp3 screen connection Edgaras Support and How To 0 2nd Nov 2007 11:51 am
PC not detecting USB Connection JamaicanGambit Support and How To 5 10th Apr 2007 5:15 am
USB Data Pins lattesurf General Discussion 11 29th Jan 2007 1:42 pm
continue..of shorting pins Support and How To 7 17th Jun 2006 4:42 pm
people please help me-(shorting pins) NICE-GUY Support and How To 1 15th Jun 2006 12:38 pm
