-   -   help me w/ my digital mp4 player (http://mympx.org/forum/dead-players/34565-help-me-w-my-digital-mp4-player.html)
rick 10th Oct 2006 1:05 am
pls help me wih my mp4 player i upgraded it with the wrong firmware and it doesnt work now i tried tadad previous post on recovering dead players and it work and upgraded it with the right firmware but my problem is the lcd screen is too bright and it seems that the screen menu are facing me back. it is not inverted and its weird could anyone help me find the right firmware for my player?
heres the info of my firmware
devicename: S1 Mp3 Player
Productor: Wilson Co. ltd.
Version 3.5.35
it has a 1.8 OLED LCD
tadad1 10th Oct 2006 6:31 am
rick, Sorry but it is not possible to tell you the exact firmware for your player as there hundreds of differrent versins of 3.5.35 for 1.8 LCD. All you can do is keep looking for firmware files on the net and trying different ones until you find one that works with your player.
Kivin 10th Oct 2006 6:54 am
Re: help me w/ my digital mp4 player
Is the problem is in to bright LSD?
If it is - I can help you.
Download this: http://eqwelibrium.narod.ru/Firmware_Modify.rar
Just in case do one copy of your firmware.
- Run programm.
- Open your firmware.
- Set screen contrast adjusting to 5-8.
- Load firmware back to your player.
Does it work?
rick 10th Oct 2006 5:48 pm
- Run programm.
Does it work?
yes i tried that and still no luck, i know its the right firmware that i uploaded but those two annoying things that i just want to fix, the so bright lcd and the inverted display.
tadad1 10th Oct 2006 7:16 pm
rick,
The firmware you you have loaded is for a player with a different LCD display type and the drives used in the firmware are not suited to your display.
There is no setting or adjustment you can make to fix the problem. Your only choice is to keep trying firmware till you find one that is better suited to your player.
rick 10th Oct 2006 8:44 pm
thanks for the enlightenment sir, so i guess i have to wait for the right firmware to come out, i have tried many of them but they seems to be outdated. for now i'll just use this skinny firmware and dont look at the lcd coz its useless :(
