MP3 System operation Does not Load
Old 11th Oct 2006, 11:00 am
Default MP3 System operation Does not Load
Hi my friends
I bought a MP3 player from china and I made the firmware upgrade like ask the manual, after this the operation system does not load anymore.
I already tried everything, but the MP3 operation system does not load.
The conexion between MP3 player and my pc is ok, but I donīt make the firmware upgrade or recorver the inicial configuration.
I transfer files from PC to Mp3 and the Mp3 to Pc normally.
Please help me to solve this problem.
Old 11th Oct 2006, 10:31 pm
Default Re: MP3 System operation Does not Load
rcsabbag , can your player still be reconigsed by the MP3 Utilities Upgrade Tool? If so, you need to try random firmwares with specifications as close as possible to your current player. These can be found in the downloads section Here.
If your player cannot be reconigsed by the MP3 Utilities Upgrade Tool, then you need to follow the Dead Player Recovery Guide Here.
Good Luck.
Old 12th Oct 2006, 2:48 am
There is conection between my Mp3 player and the Computer.
I can use all manage softwares to make firmware upgrade but the operation system does not load.
Is there another solution?
Old 12th Oct 2006, 6:24 am
rcsabbag , if that's the case, then currently the problem is that you still have not found the compatible firmware to flash into your player yet. You need to keep trying various firmwares until you get the right one.
Old 16th Oct 2006, 7:13 am
I tried all firmwares from this webpage.
Do you have another solution?
Please help me.
Best regards
Old 16th Oct 2006, 7:25 am
rcsabbag, s1mp3.org has a firmware list but most are a little dated.
http://s1mp3.org/en/downloads_fw.php
Old 16th Oct 2006, 12:37 pm
Hi may friend !!!!
I am without luck ...
I tried all possibles firmware in the webpage send by you but my MP3 player still damage.
I am very sad with this situation because I am without support by the seller, I will cancel the payment until this problem was solved
thanks a lot
Old 16th Oct 2006, 8:30 pm
rcsabbag, I suggest you post some images of your player and information on where you purchased it. If another member has a similar player from the same supplier they may upload the firmware for you.
Operation of Raremono / thanko / 1.8" (1.5") metal Blaze Support and How To 22 23rd Jun 2008 2:29 am
System Clock chandnichowk Support and How To 7 17th Nov 2007 4:32 pm
Username Change System deepakrr Miscellaneous 1 1st Apr 2007 2:56 am
System Time dacdiver Support and How To 8 11th Feb 2007 12:08 am
The system cannot read from the specified device Zurky Support and How To 2 14th Dec 2006 8:45 am
