DEAD PLAYER(battery?)
Hi
Something has happened to my mp4 player and know i cant turn it on. When it is connected to the computer i can still access the files and it charges and i can even listen to my music with the headsets via the mp4 player(still connected to the computer). But when i try turninng it on without it connected to the computer its just doesnt turn on. WHAT CAN I DO? |
Re: DEAD PLAYER(battery?)
Dulithak , your player's battery may have some problems or the connections from the battery to the mainboard may have problems. Probably your battery is totally dead/damaged, or some battery voltage regulator on the mainboard is damaged. i'll suggest you contact your seller for a replacement set if it is still under warranty.
| All times are GMT -7. The time now is 11:24 pm. |
