Player restards when using Record
Old 29th Oct 2006, 3:15 am
Default Player restards when using Record
I have a problem with my player.
Each time I want to start the Voice Record program the player shows the yellow screen with the hourglass and restarts.
I recovered the original firmware I extracted when I got the player, but this doesnt change anything.
my Player is a Nano 2 GB Clone
Does anyone have an idea what I can do? Please help me.
Old 29th Oct 2006, 4:33 am
Default Re: Player restards when using Record
mars-online , try formatting your player with the MP3 Utilities Disk Tool or HP Format Tool 1st. A memory hack could be causing the restarts.
If after the format, the problem still persists, likely that the internal hardware components has some problems. i'll suggest that you contact your seller for an exchange if it reaches this stage.
Old 29th Oct 2006, 5:09 am
How do I remove a eventualy hack?
What exactly do I have to do?
Old 29th Oct 2006, 5:45 am
mars-online, you just need to format it with the programs i mentioned earlier. The format would remove any memory hacks.
Old 25th Dec 2006, 11:47 pm
i got the same problem as mars online but its after i formated it
Recovered Dead Player Keeps Skiping to record lfclfclfc123 Dead Players 4 15th Sep 2007 10:03 am
Record option doesn't work on TJD_1301_02 player masakupa Support and How To 3 5th Jul 2007 4:20 am
MY MP4 PLAYER DOES'NT RECORD ANYTHING! blackscepter Support and How To 4 7th Dec 2006 5:36 pm
can't record sprqy1 Support and How To 3 20th Sep 2006 9:30 pm
Can't record from Radio oxtros Support and How To 0 13th Jul 2006 9:41 am
