dead chinese MP4 (flash write protected - problem)
  #21 (permalink)
Old 5th Nov 2006, 4:01 am
Default Re: dead chinese MP4 (flash write protected - problem)
Fixxxer, nobody in this forum is able to verify which firmware is compatible with which player, not you, not me, not the admin and moderator.
You might want to contact your seller and see if they have a some firmwares to send to you.
  #22 (permalink)
And while doing that u must connect it to the USB or what? What about battery? Should I unweld it again?
How many times do I have to cross down with tweezers?
  #23 (permalink)
Old 5th Nov 2006, 4:12 am
Fixxxer, I leave the battery connected and have the player plugged into the usb. In most cases once is enough but occasionally I may have to repeat the process 2 or 3 times.
  #24 (permalink)
Old 5th Nov 2006, 4:21 am
I flashed it while holding tweezers on the first 3 pins of each side. It succeded, my display went blue, but when i restarted it (ON/OFF), its black again and it goes to adfu mode again.
what now? :?
  #25 (permalink)
Old 5th Nov 2006, 4:38 am
Fixxxer, It is supposed to go to ADFU Mode because you have reset the chip, Can you load a full version firmware to it though or is it still write protected?
  #26 (permalink)
Old 5th Nov 2006, 5:04 am
It is still write protected. I can succesfully install new firmware but only when I am holding the tweezers on some combinations of pins. Problem is that its same like i havent installed the new firmware. The screen is black again, and its in adfu mode as usual...
  #27 (permalink)
Old 5th Nov 2006, 5:28 am
Fixxxer,
Sorry I have run out of ideas, I am stumped as to why the chip has become write protected.
What happens if you go into device manager select the ADFU device and try to install it as a usb mass storage device.
  #28 (permalink)
Old 5th Nov 2006, 5:30 am
Fixxxer,
And how do u think to do that? On update driver or what? What than? I dont know how...
  #29 (permalink)
Old 5th Nov 2006, 9:17 am
Have you already contacted the manufacturer ?
  #30 (permalink)
Old 5th Nov 2006, 9:41 am
No, I havent contacted em. Manufacturor is Cool Sources, they r social, they dont have any support. :?
mp3 write protected,.. plz hlp mohitanand Dead Players 6 5th Apr 2009 9:13 am
Dead Apacer AU822 Need help "The disk write protected& Pihas Dead Players 0 15th Apr 2007 5:13 am
Flash write protected BSOD Dead Players 8 22nd Jan 2007 1:44 am
Disk Write Protected blackpanther Dead Players 9 15th Nov 2006 2:33 pm
half Dead Sony MP4 player... disk = write protected... karl_mrqz Dead Players 6 10th May 2006 7:33 pm
