dead chinese MP4 (flash write protected - problem)
  #41 (permalink)
Old 18th Nov 2006, 3:48 pm
is it dead ?
  #42 (permalink)
Old 16th Oct 2008, 3:29 am
i need mp3 player firmware
chip atj2091n
hynix
screen size 96x32
monocrom lcd blue back light
  #43 (permalink)
Old 16th Oct 2008, 3:32 am
please help me i havr tired to upgrade firmware
i have already try morethen igb firmware
my orignal firmware version is 9.1.51
and i have no backup of this firmware
chip atj2091n
memory chip hunix
screen size 96x32 blue back light
monocrom lcd
please help me
and send me firmware for this
  #44 (permalink)
Old 16th Oct 2008, 3:34 am
just resold memory chip for recover write protect error
  #45 (permalink)
Old 17th Oct 2008, 8:28 am
usually it is because your memory Flash has dirt,so its legs has connected, you can use a brush to clean its 16 legs, the best method is using a electric tool to heat its 16 legs again!
  #46 (permalink)
Old 17th Oct 2008, 10:57 am
well i have saw all your conversation and in that conversation most of the things are very illogical.
Your problem is that when you try to install the firmware (after the message SCANNING THE HARDWARE) it said FLASH WRITE PROTECTED.So that means that your FLASH chip is not responding to the firmware and it is clearly the FLASH IC problem.
The only solution you can try is that take the HOT AIR GUN and apply the paste on the flash IC pins on both side and rehot the flash ic,i am sure with this your problem will be solved.
And if by this too your problem is not solved then replace the FLASH IC.
Throw the tweezer out because the short pin procedure only be used if your mp3 is not detecting as ADFU device and all the hardware of your mp3 is OK.
IF it is detecting the no need of that procedure.
Please be logical and dont run after every thing what you read.
mp3 write protected,.. plz hlp mohitanand Dead Players 6 5th Apr 2009 9:13 am
Dead Apacer AU822 Need help "The disk write protected& Pihas Dead Players 0 15th Apr 2007 5:13 am
Flash write protected BSOD Dead Players 8 22nd Jan 2007 1:44 am
Disk Write Protected blackpanther Dead Players 9 15th Nov 2006 2:33 pm
half Dead Sony MP4 player... disk = write protected... karl_mrqz Dead Players 6 10th May 2006 7:33 pm
