Dead player help please
Old 3rd Nov 2006, 8:49 pm
Default Dead player help please
I have a 2g player that is dead. When I switch it on I get a black screen with the hourglass icon which doesn't go away. I don't have a backup of the firmware so I need some help. The chips are:
ATJ2085D
Samsung 632
I think the firmware version is 9.0.48
Please help
Regards
Max
Old 3rd Nov 2006, 9:00 pm
himax, This is going to be a problem for you because at present there is no way to create a viable backup of 9.0.XX series firmware. In a situation like this the Dead Player Recovery Guide would be the best method to recover your player but you would need a full version of your firmware to do this.
The only options I see for you are to check the mini cd that came with your player to see if there is a copy of the firmware there.
Contact your supplier for a copy of the firmware.
Return your player for replacement.
Old 3rd Nov 2006, 9:09 pm
Default Re: Dead player help please
Thanks tadad1,
I have checked the CD and there is no firmware. I am hoping that someone else might have the firmware on a different CD.
I have already tried all the firmware I can find, so far no good.
Regards Max
Old 3rd Nov 2006, 9:42 pm
himax, What size is your screen?
Old 4th Nov 2006, 4:11 am
It's a 1.5in screen.
Old 4th Nov 2006, 5:11 am
himax, I have a full 9.0.43 for 1.8 LCD but it will be no use to you with a 1.5 screen.
I just looked at your original post and if your chipset is ATJ2085D I do not think your firmware would have been a 9.0.XX series as they are used on the ATJ2097 and the CTW500 chipsets which support 2.0 inch + LCD's. The ATJ2085 usually runs the 3.5.35 or 3.5.37.
MP4 DEAD THIS IS THE CPU AND BOARD POST, DEAD PLAYER manikakoto Dead Players 0 9th Feb 2009 3:08 pm
Dead Player i think very dead... DzoniHSV Dead Players 13 10th Aug 2007 12:13 am
dead player, so very very dead Kosh Dead Players 4 1st May 2007 6:48 am
Dead well almost dead MP4 Digital Player Zest Dead Players 6 28th Jul 2006 9:59 pm
