tnx i tring
tnx fo the hlep |
who to Upgrade
this bin ? Upgrade Tool dont let me to up to player |
omg your englis :/ any1 understanda him ?
Idanbolig, When you try to upgrade your player are you getting any warning messages, what are they?
Idanbolig, Do you get this message with all firmware you try to use?
When you start the Upgrade tool are you getting a message that your player is in Recovery Mode? |
Yeah maybe it is right... Does it do for all firmwares ?
If it does maybe your uttility went mad and it is uploading the same fw all the time... you should then install other version of it. |
yes is give me
message "Youer player is in Recovery Mode" wat do now? i geting Full firmwarel and up to my player see in the pic here but is dsn't Recover http://m.1asphost.com/Diabolic5454/STRP.JPG |
Yes then you turn your player off and then on. After it is recognised by PC
- if it is ADFU device, look for other full firmware - if it is recognised as a Mass storage drive look for dumps |
but i tring all full firmware
don't work |
| All times are GMT -7. The time now is 6:24 pm. |
