please help!!!! firmware for my player srx-a7
Old 7th Nov 2006, 7:55 am
Default please help!!!! firmware for my player srx-a7
please they help me my to player died! I am needing one firmware
already I verified the majority of firmwares found in the site but none of them functioned with my player !!!!!!!!!
SPECIFICATIONS:
IPOD NANO CLONE
DISPLAY: 1.5'
MAINBOARD: SRX-A7 V0.2 2006-07-22
CHIPSET: ATJ-2051H
MEMORY: 2GB
Old 8th Nov 2006, 8:14 am
I have the same chip !!! TRy to recover it in the same way like me:
Follow the recovery guide and then : Full firmware is I think:
http://www.mympxplayer.org/t18v25bin-df241.html
And the dump you will upload after should be :
http://www.mympxplayer.org/firmware-...ltd-df392.html
Hope it will work
Old 9th Nov 2006, 2:58 am
I made everything, I caught firmware that it recommended and nothing to me, according to emends of recovery when we place full firmware player we will have to be with the blue screen in mine this we do not happen we continue off ...... I we do not know what to make :cry:
Old 9th Nov 2006, 5:57 am
No !!! IT is not true that it is good if you have blue screen... IF the player is recognised as a Generic USB device it is the right full firmware and you are then ready to upload dumps... No matter with blue screen !
Old 10th Nov 2006, 2:44 am
it is certain that firmware adjusted for mine is this chip? Mine mp4 continues without binding, followed the steps of recovery and nothing. You it could explain accurately the procedure all of as you it recouped its to player?
Which the version of the program that you it used to recoup?
please it helps me !!!
Old 10th Nov 2006, 6:19 am
after some attempts I noticed that boot soon appears with luminosity and after backlight if it erases and he is stopped in boot initial. I obtain to pass archives normal for mp4 as pendrive it this normal one.
Old 10th Nov 2006, 6:33 pm
ITS GREAT! 8)
I obtained you finally Groovy helped me very but I obtained with another one firmware http://www.mympxplayer.org/pma300010...ump-df373.html perfectly functioned only with a detail the volume control alone diminishes but the remaining portion this completely normal
8)
Old 11th Nov 2006, 7:24 am
YEAH MAN.... That s great
Congratulations !!!
