mp4 firmware
Old 18th Nov 2006, 3:45 pm
and like ADFU or MAss storage ?
if mass storage look for right dump file...
if adfu lok for full firm...
Old 19th Nov 2006, 12:45 pm
Default Re: mp4 firmware
it's mass storage you don't know the good firmware please because i have tried many firmware and dump without succes. :cry:
help me please
Old 19th Nov 2006, 2:30 pm
louis20, The hardest part of player recovery is finding the right firmware. It is not possible to tell you the exact firmware you need as there are so many different variations now each one specific to their players hardware components. The only thing you can do is keep trying firmware till you find one that works with your player.
Check the players mini cd as sometimes there is a copy of the firmware on it.
Also try contacting your supplier and see if they will send you a copy.
Old 20th Nov 2006, 11:50 am
thanks i'm going to try this solution
