HELP ME! HELPME! PLEASE for mp4 mp680-cl-v11
Old 10th Nov 2006, 3:28 am
Default HELP ME! HELPME! PLEASE for mp4 mp680-cl-v11
hallo! :cry: :cry: :cry:
someone has this player?
it has black sides and forehead and back mirror and 2 speakers
image in avatar
enough to use the software s1fwx to extract firmware dump?
thanks! thanks!
HowTo: Extract and Repair Firmware
Extracting your players firmware is a very good idea just to create a backup of the original firmware files. It's no promise that you could always backup your player after some bad firmare update, but at least you have some more possibilities. First download newest version of s1fwx from this page and extract the archive. Then connect your mp3 player device to your computers usb port and wait until it gets detected. Now doubleclick the extracted file "extract.bat" or run "s1fwx f dump.bin" from the windows commandline console. Skip the disclaimer by pressing space and select the drive your player gets mounted to. (eg. if detected drives displays "<x>" then choose drive "x:" by pressing x) Now s1fwx should start extracting your firmware, this may take arround 10 seconds. If all went well and no error gets displayed it will display the content of the extracted firmware file as it was readden from your player.
Before you could update your player with this firmware file using the original "Mp3 Player Update Tool" you will first have to repair it. Start "repair.bat" or type "s1fwx r dump.bin". A backup will be saved at "dump.bi$" automatically and the repaired file is now available as "dump.bin". Notice that its not possible to do a firmware recovery with this file (only regular firmware updates) since there are missing files needed by the "Mp3 Player Update Tool" recovery mode. Since this files couldnt be found on your player you will need to get them from some official firmware file which is known to work with your players hardware. Either you first could recover to this firmware before updateing to "dump.bin", or you could insert the needed files from the original AFI file into "dump.bin" using s1fwx. The original firmware has to support your flash chip(s). It doesnt matters if its just using different backlight or key-mapping.
my specifications:
chip samsung 616 k9k8gd8uda pcb0
atj 2085w
board: mp680-cl-v11 2005-11-02
this is chinese without brand i buy it on ebay
thnaks...thanks ...thanks :cry: :cry: :cry:
my mail serrefloralia@libero.it
I have MP4 player dead helpme please darkpower15 Dead Players 3 11th Nov 2007 5:27 pm
firmware need helpme ttkh85 Dead Players 5 9th Aug 2007 3:45 am
The admin, can you helpme??? Stranyer Support and How To 0 20th Dec 2006 7:49 pm
Need FULL FW to MP680-CL-V11 2005-11-08 schopf Dead Players 0 26th Nov 2006 10:54 am
DEAD MP4 MP680-CL-V11 2005-11-02 serrefloralia Dead Players 1 11th Nov 2006 2:25 pm
