-   -   help dead nanolike player atj2051H pls.. (http://mympx.org/forum/dead-players/34923-help-dead-nanolike-player-atj2051h-pls.html)
awitee 10th Nov 2006 3:41 pm
hi pls help me, i alredy tried everything, here is what is hapening:
first i put t to adfu mode by shorting
then i upgrade using full firmware
then my computer reads it as disk drive (blue screen)
theni install S1 Mp3 3.5.37 Wilson Co. Ltd. Firmware
then the screen shuts off, but my comuter can still read it as disk drive
then i install a dump.bin (if i use it for the second process, my player needs to be adfu agen coz pc cant read anymore)
after i upgrade with dump, a screen shows a picture that has "upgrade ----> 3.xx" in it, but then returns to the blue screen, and needs to be shorted agen....
ppplllssss help me
lattesurf 11th Nov 2006 12:59 am
Re: help dead nanolike player atj2051H pls..
awitee , what you did was correct. The only problem is that the firmware dump or the full and dump firmware combination was not compatible with your player.
You'll need to try various combinations of FULL firmware with firmware DUMPs. If 1 dump file does not work, try another dump file.
Groovy 11th Nov 2006 7:22 am
HEY use firmwares as I did....
Full is in download section and the file is called T18 !
And dump is here :
http://www.mympxplayer.org/firmware-...ltd-df392.html
awitee 11th Nov 2006 4:55 pm
groovy, i already tried that man.. only got the blue screen...
thx for the replies guys
Groovy 13th Nov 2006 10:23 am
hm... then try links ;)
