Firmware "atj2085h and hynix"
Old 15th Nov 2006, 10:14 am
Default Firmware "atj2085h and hynix"
I have dead player that is uptaded wrong firmware ,and my friend has same problem about memory that shows only 18 mb. Can someone help me ?
Old 15th Nov 2006, 6:59 pm
Default Re: Firmwire "atj2085h and hynix"
teen , can your player still be detected by the MP3 Utilities Upgrade Tool? If so, you will need to try various firmware dumps in the downloads section until you get the right one.
If it can't be detected, you will need to follow the Dead Player Recovery Guide Here.
About your friend's memory problem, use the MP3 Utilities Disk Tool and select "LOW" level format, then in the Parition & Encrypt tab, slide the slider all the way to the left (min) and click on Format. It should rebuild the memory partition.
Old 22nd Nov 2006, 2:51 am
Default Re: Firmware "atj2085h and hynix"
I tried it but I have no result . It shows only 108 mb now . And I tried lots of firmware but I couldn't fount correct one. Can anyone help me ?
Old 22nd Nov 2006, 3:07 am
teen , regarding your friend's 108MB player, if the format had been done, the actual memory capacity is 128MB. If the player initially showed more than 128MB (eg 1GB or 4GB), it has been hacked.
Regarding the dead player, it is very very hard to tell you which firmware is suitable for which player. You have to try every single firmware dump until you get the right one.
*Firmware Request* Nano clone,8gb,ATJ2085H chip, 1.5" s dimpy Dead Players 3 15th Dec 2007 11:50 am
hyundai mp3 stucks at starting... 1580DCAD "HYNIX/SAMS glas Dead Players 3 24th Oct 2007 11:26 pm
"Invalid upgrade firmware file" & "Flash AmitS Dead Players 1 26th Jan 2007 8:09 am
Firmware needed for fake nano atj2085h hynix board maximumadrenaline Dead Players 2 26th Nov 2006 1:57 am
