Is possible an eprom empty issue?
Old 20th Nov 2006, 5:00 pm
blink18273, Are you measuring your screen diagonally from corner to corner? I think that there may be a couple of 1.2 inch firmware, they were some of the first ones uploaded when the site started. Not sure if they are still their though.
.fw files are generally full version firmware from manufacturers and .bin files are usually firmware dumps. Full firmware can be in .bin format as well though.
Show us a picture of your player to check your screen size.
Old 20th Nov 2006, 7:18 pm
Thanks, more questions, when i need to repair the dump file, i put the player on recovery mode, i load the firmware 3.5.37 from the dld site, then i load a bin file, but how can i know what is the correct bin file or when i need extract a bin and repair?
FA15-16R issue, what to do now? l0stc0ntr0l Support and How To 0 21st Jan 2010 7:38 am
Empty File! -- help please brerfox Support and How To 1 23rd May 2009 10:13 pm
charging issue moghm Support and How To 8 25th Mar 2007 11:47 pm
FPS Issue yngwie0001 Video related 3 23rd Jan 2007 7:52 am
Help- my mp4player seems to be empty (but it isn't)! zzyzzyxx Support and How To 2 7th Dec 2006 8:48 am
