Is possible an eprom empty issue?
Old 15th Nov 2006, 12:27 pm
Default Is possible an eprom empty issue?
Hi there,
i have an ipod nano clone 1.5 and 2 gb, with a blue screen, i put my device connected to my pc usb , start to charge battery but in some time get a blue screen, someone toldme that have an eprom deleted and need to send the unit to service, is it possible? can i recover my unit updating the firmware? can you tellme the correct procedure to upgrade the firmware? i can see the disk as usb drive, Thanks in advance
Old 15th Nov 2006, 2:13 pm
blink18273, If the player is new and under warrenty I suggest you seek a replacement. If replacement is not an option then you can try reloading the firmware, there is a guide to this in the Knowledge Base here
http://www.mympxplayer.org/how-to-up...ayer-vt46.html
Updating the firmware is quite simple however finding the right firmware is not and unless you have a backup of your original firmware you may have to try many different ones till you find one that works with your player.
If your player is not recognised by the MP3 Upgrade Tool then you will need to follow the Dead Player Recovery Guide here
http://www.mympxplayer.org/dead-play...ide-vt567.html
Old 15th Nov 2006, 8:32 pm
Thanks, i have 2 more questions, how can i uncompress a .7z file, this extension is not recognized by the firmware upgrade tool, and the other question is, do you have a full firmware for a S1 MP3 Player, the firmware tool says that this is the device model
Old 15th Nov 2006, 8:37 pm
blink18273, You can use 7zip or winrar to extract .7z files. Re full firmware all these players are s1mp3 players but you will find a selection of full firmware here
http://www.mympxplayer.org/full-firmware-dc35.html
Old 16th Nov 2006, 7:42 pm
hi again, i get my chpset numbers, do you know where i can found a firmware for a chip samsung 622 k9wag08uia ? Thanks.
Old 16th Nov 2006, 8:40 pm
blink18273, That is your memory chip number, your main chip will be smaller and possibly marked ATJ2085*.
Unfortunatly it does not help terribly much as there are still 100's of firmware for this chipset so you will just have to keep trying firmware till you find one that suits your player.
Old 19th Nov 2006, 11:35 am
tadad1, i have the correct number of my board, is ATJ2085W, i think this is not common, do you know where can i find the firmware? Thanks.
Old 19th Nov 2006, 2:37 pm
blink18273, That is quite a common chip version, have you tried all the firmware for your screen size in the download section.
http://www.mympxplayer.org/firmware-dc4.html
Old 20th Nov 2006, 3:54 pm
i have adoubt about the size of the screen of my player, with a ruler the measurement is 1.2, i have the 3.5.35 and 3.5.37 only for screens 1.5 and 1.8, is possible to make a firmware 3.5.35 for a 1.2 screen?
Old 20th Nov 2006, 4:28 pm
one more question, what is the difference between a .fw file and a .bin file, when in need to load the first and when i need to load the bin file, i see this specs, the dump is not the same of the ACT_V3.5.35
Processor: ATJ2085W
Memory: 2GB Samsung 622 K9WAG08U1-A
Dump: 3.5.37
SC85051F
2006/04/25
ACT_V3.5.35
FA15-16R issue, what to do now? l0stc0ntr0l Support and How To 0 21st Jan 2010 7:38 am
Empty File! -- help please brerfox Support and How To 1 23rd May 2009 10:13 pm
charging issue moghm Support and How To 8 25th Mar 2007 11:47 pm
FPS Issue yngwie0001 Video related 3 23rd Jan 2007 7:52 am
Help- my mp4player seems to be empty (but it isn't)! zzyzzyxx Support and How To 2 7th Dec 2006 8:48 am
