{SOLVED} help please, about firmware upgrading
Old 20th Nov 2006, 3:35 am
Default {SOLVED} help please, about firmware upgrading
why the firmware upgrader shows that error if the same version of the player is the same version of the file??
help me please, my player is dead and i don't know how to fix it
__________________________________________________ ___________
I could fix it with this Firmware!
http://www.mympxplayer.org/dump-chin...043-df403.html
thanks a lot Fabien and Admin!!!!
God bless You two!
the only trouble, that now my player is in chinesse, how can i translate it into english??? or spanish???
Old 20th Nov 2006, 3:51 am
nickyblast, Where did you get the dump from?
Is it extracted from your own player?
What was it extracted with?
Old 20th Nov 2006, 3:56 am
i'll explain you all:
i extracted a dumb file from my player, and i tried to upgrade with another version, i killed my player, and when i tried to upgrade with my backup dumb file, shows that error.
but i relizaed that my dumb back up is damagen (unknown reason) and now my player is dead and i don't know what firmware will live it up again.
Old 20th Nov 2006, 3:59 am
Default Re: help please, about firmware upgrading
when i turn my player on, it's start with the icon "waiting" and then stay on blue screen, the computer reconize it perfectly, my player is a nano clone, and i think the firmare version is 9.0.43
Old 20th Nov 2006, 4:24 am
nickyblast, Can you email your dump to me at tadad1@gmail.com and I will see what sort it is.
The reason it will not work is because 9.0.43 version firmware is quite new and s1fwx can not properly extract a working backup yet.
Send me your dump and I will see what I can do.
Old 20th Nov 2006, 9:47 am
Thank you very much!
i'll send it to you for sure, and please see what you can do, thanks
Old 22nd Nov 2006, 7:30 pm
Default Re: {SOLVED} help please, about firmware upgrading
God bless You two!
Old 22nd Nov 2006, 7:55 pm
hello, i have firmware 9.0.48
and i really wanna change the theme, is there anyway to put that firmware into my player?
would it work? downgrade or something?
Old 22nd Nov 2006, 7:59 pm
beware! i extraxted my dumb file from my player, and when i tried to usgrade it again into my player, the dumb file were corrupted, and my player was dead
Old 23rd Nov 2006, 2:43 am
xeongx,
i just killed my mp4 player with the same firmware 9.048. do you happen to have a copy of the firmware?
please send it me, need it badly. I have a dump file, but it won't work. My email is ogie_d@softhme.net.
Thank you very much.
[solved] Ak2025 nano dead without upgrading! Need help please! son1x Support and How To 11 24th Jun 2010 11:12 pm
Firmware upgrading problem NEEDHELP_PLZ Dead Players 0 19th Oct 2008 7:45 pm
Anyone try Upgrading from 3.5.X to the new 9.X firmware sumbody General Discussion 3 26th Jul 2007 9:45 am
Upgrading my Firmware oneworldteam Support and How To 5 22nd Mar 2007 3:14 pm
[solved] busy icon after upgrading the mp4 mashranga Dead Players 3 6th Oct 2006 5:23 pm
