SRX-A9 PLAYER HELP
Old 21st Nov 2006, 4:08 am
Default SRX-A9 PLAYER HELP
hi friends
mp4player pcb having SRX-A9-51V0.2 1GB space decreases 250 mb and reset itself after 50th part when I install Dump firmware... what should I do?
Old 21st Nov 2006, 4:25 am
Default Re: SRX-A9 PLAYER HELP
AmedliDrej , is the player currently working now? If you are unable to get it to start-up, you will need to try various firmware dumps in the downloads section for your screen size until you get the right one.
If it is working, but keeps restarting, i'll suggest a format on the player. The guide is Here.
Old 21st Nov 2006, 9:09 am
@lattesurf very thanks mate
