NEED firmware for Samsung 638
If any one can get my a bin for a nanoclone with a Samsung 638 chip i will be very thank full
Heres a exact pic http://www.mympxplayer.org/nano-clon...l-2-df407.html |
Re: NEED firmware for Samsung 638
chickenclaws , it's very difficult to tell which group of firmwares would be suitable for your player from the outer casing. Some players with exact same casing and menus, and even from the same seller, have different sets of firmwares.
What you'll need to do is open up your player, and look for the 2nd largest square chip. Usually, it's ATJ20xxx, and from there, go to the downloads section and look for those firmwares for your screen size and related chip number, and try them. It doesn't matter if the last alphabet is different (eg ATJ2085H and ATJ2085W), the main thing is the number. |
The number on mine is very differnt
its ak1010 then under it is 6026aa :idea: |
| All times are GMT -7. The time now is 8:52 pm. |
