Look for firmware...
Old 23rd Nov 2006, 5:09 pm
Default Look for firmware...
Hello everyone, i'v got a problem with my mp3/mp4 player 1G , it's very similar like other ones here inside the forum, but is "I-Joy" kind
Look
And i just need this firmware (it's exactly like this one photo post in this forum, but i cant' find it )
The problem was trying to up-grade the original firmware, but i crap it ! ops: , and then i found only a firmware works but in chinesse :roll: , and only works the voice recorder... well, someone can help me please ?? :wink:
Old 23rd Nov 2006, 6:11 pm
dragonforce45, I do not know if I can help you with your Asshole problem but I may be able to help you with firmware.
There are quite a few 1.5 nano clone firmware in the download section that use the theme you show.
I suggest you download s1res Here
http://www.mympxplayer.org/s1res-v19-df349.html
Then start downloading firmware from Here
http://www.mympxplayer.org/medium-co...reen-dc15.html
Then open them with s1res and look at the images in the firmware and find the ones that use the same theme and try them.
There is also one I have uploaded that may help Here
http://uploaded.to/?id=fe0004
If you find one that works and it is Chinese this can be easily fixed in the player settings.
Let us know how you go.
Old 23rd Nov 2006, 10:42 pm
Default Re: Look for firmware...
Tadad1 thanks for you atention, i dont have an idea for what is that program "s1res_v19" i tried but i dont know anyting ops: .
The other thing is i tried a lot of those firmware posted on the section of donwload, but how i said only one works, but in chinesse, even get in the settings of the mp3 player, only works the voice recorder :roll:
Sorry by my bad english ops: , im spanish citizen, but a few language english learned .
I don't know anything else more to try :cry:
