I need to update my firmware HELP ME
Old 24th Nov 2006, 8:46 am
Default I need to update my firmware HELP ME
Hello every body. I need to update my mp4 player because is not workung well. When I treat to record voice the device goes to reset and music player only goes to 26 song and after start reset. I believe the problem is the firmware and I want to update it. Some body could tell me how? Thank you.
Old 24th Nov 2006, 3:07 pm
Default Re: I need to update my firmware HELP ME
markitos04 , what i see is likely a hacked memory. i would suggest you formatting your player with MP3 Utilities Disk Tool first. The guide is Here.
Try it out and see if the player still resets.
Old 28th Nov 2006, 8:28 am
Hi, I did the formatting procedure and my mp4 now has 108 mb and I bougth it as 2 Gb. May I recover memory space? If this is a hacked device it will have a solution or not? PLEASE Help ME!!!!!!
Old 28th Nov 2006, 3:57 pm
markitos04 , i'm afraid that there is nothing much you can do about the memory. As the memory chip was originally a 128MB hacked to show 2GB, you only physically have a 128MB chip.
To further verify, you can open the player and check the serial number of the largest chip against the manufacturer's website.
What i can suggest is to contact your seller and demand a full refund. As i'm sure you paid alot of money for a 2GB and ended up with a 128MB player.
Old 28th Nov 2006, 4:48 pm
Hi, lattesurf. Thnak you for your valuable support. I checked the serial number on the memory chip and this is HY27UF081G2M, and as to I can understand, the memory is of 1GB. I will take your recomendation and I will look for the seller because this is selling a lot of this mp4 kind.[/size]
Regards
Old 28th Nov 2006, 5:14 pm
markitos04 , from the Hynix datasheet, HY27UF081G2M is a 1Gigabit chip which approximately is about 128MB. Not a 1GigaByte chip.
Firmware update Oman Support and How To 0 4th Aug 2008 11:48 am
I need to update firmware gaudier Support and How To 2 29th Oct 2007 1:28 pm
Update the firmware Help!!!! _AXS_ Support and How To 1 7th Jan 2007 1:42 am
firmware update milindbendre Video related 1 4th Aug 2006 7:01 am
Firmware update or not cherva Support and How To 5 4th Jul 2006 4:58 am
