ADFU mode, not able to load full FW
Old 6th Dec 2006, 8:59 pm
CaptainZap, I tried to upload my dump yesterday. It took long time to upload, but I was not able to locate the file. I had it under member's upload. May be you can guide on upload.
Old 7th Dec 2006, 3:28 am
Default Re: ADFU mode, not able to load full FW
Send me your firmware by mail then...at "capta1nzap@yahoo.com"
Old 7th Dec 2006, 5:28 am
Hi
I tried to load this and it says upgrade is a success but when I switch of and on I get a blue screen and it switches on and off. It did connect briefly but not long enough to do anything with
Old 7th Dec 2006, 10:59 pm
CaptainZap,
I just emailed you the dump files.
Mark2,
If your player was stuck in ADFU, it seems like now it is back to USB mode. If that is the case all you need to do is reload your own original dump file, & you shuold get back to original screen display.
If you do not have original dump from your own player, you will have to keep trying all dumps you can find (9.0.43 or 9.0.48 or 9.0.50). Mine is 9.0.43 & works on ATJ2091H chip.
I also have Visual Land brand nano clone (not opened, so do not know the chip) that also uses 9.0.43, and is working perfect without a radio glitch. So I tried to load that dump on my Kudez brand nano clone, but unfortunately it does not work -gives me blue screen.
In other words, even with same FW version, the dump file can make a huge difference.
I will be happy to email you my dump files from all three nano clones I own.
Good luck.
Old 7th Dec 2006, 11:11 pm
Mark2,
I missed reading your note saying it is going on & off.
This means you have loaded a dump that is not letting your player load fully to be recognised by pc as a USB device. You will have to physically short the memory & while holding in short, load the right dump file. (I had this problem once, & it worked that way). You may have to reload full version of 9.0.50 again to get blue screen that does not turn on & off by itself.
  #16 (permalink)
Old 8th Dec 2006, 1:55 am
Hi Kunal
I have just tried what you suggested several times but the player still keeps going on and off. When I look in explorer it recognises two removable drives one abou 57k and the other about 3800k bu it switches off before I can do anything with it.
  #17 (permalink)
Old 8th Dec 2006, 2:16 am
mark2, Your player is stuck in a boot up loop. It starts to boot then hits a problem then resets. The fact that the upgrade tool reports a success is because it loaded the firmware without any problems it does not mean that the firmware is suited to you player.
To kill the reset loop I suggets you use the Dead Player Recovery Guide to reset you player. You will then need to load a full version firmware to take it out of recovey mode so you can try some of the other 9 series firmware.
http://www.mympxplayer.org/dead-play...ide-vt567.html
  #18 (permalink)
Old 8th Dec 2006, 2:36 am
Hi Tadad
I have tried the dead recovery guide and have tried to use fw 35.35 fw 35.37 fw 9.0.42/3 and none of them load fw 9.0.50 loads and says success but it still switches on and off. The Chip is AJT2091H do you think I need the fw 9.0.48 ? is that the problem ?
  #19 (permalink)
Old 8th Dec 2006, 3:39 am
tadad1, Sadly if none of the others are helping there may not be alot you can do at the moment. I have seen no full 9.0.48 anywhere and I have done some looking.
  #20 (permalink)
Old 8th Dec 2006, 3:46 am
tadad
Yeah I have looked as well ..I wonder why its not available anywhere? someone must have it ...when do you thinks 1fwx will be able to extract it ?
mp4 stuck in adfu mode. adminn Dead Players 5 1st Feb 2010 1:22 pm
Can't get the player to adfu mode zrock Dead Players 7 15th Feb 2009 9:19 pm
How Can Update Mp3/Mp4 in Recovery Mode (ADFU Device Mode) oxygen0077 Firmware 1 28th Oct 2008 2:15 pm
Help with getting into adfu mode moneybankz Dead Players 7 25th Apr 2008 3:49 pm
Can't get into ADFU mode richard_s Dead Players 2 28th Nov 2006 8:00 am
