-   -   ADFU mode, not able to load full FW (http://mympx.org/forum/dead-players/35147-adfu-mode-not-able-load-full-fw.html)
tadad1 8th Dec 2006 6:20 am
mark2, My understanding is that "wiRe" is working on a totally new extraction tool that will replace s1fwx. I have no idea of the timeline though.
mark2 8th Dec 2006 6:42 am
Yeah ..will have to wait for that I suppose
kunal 8th Dec 2006 4:27 pm
Mark2, I had this loop problem after loading one of the dump files. It was not running long nough even to get recocgnised on "MP3 Player Product Tools 4.19". But then shorted the memory & reflashed with 9.0.50 which brought it back to steady blue screen. At this point I was abl to load my backed dump for this particular player.
Question 1: Is your player going in loop mode right after flash with 9.0.50? If so, this might not be the right 'full FW' for your player. But you may still try loading other dumps while holding memory shorted.
Question 2: Do you have your player's own dump file? If you are able to load it after 9.0.50 & still getting having loop, then 9.0.50 is definately not the answer to your probem.
I can e-mail you three dumps from my personal collection of mp4's. I was not successful in uploading files here on website.
mark2 9th Dec 2006 4:03 am
Hi Kunal
Yes it goes into loop mode straight away and I cant get it recognised long enough to load anything. I would appreciate the dump files if you can mail them or upload to a server. Email is halkewl@hotmail.com.
CaptainZap 9th Dec 2006 5:06 am
Re: ADFU mode, not able to load full FW
I didn't receive your e-mail.Can you please send it again.Thx
sak_cheegii 9th Dec 2006 5:42 am
Hey guys
Don't forget to disable Your ANTIVIRUS software when you are extracting your players firmware using S1FWX. Antivirus will break your extracting firmware! Also Memory is broken if it freezes at 20% when you uploading any of (Full or dumped) firmware. (Show like "UNKOWN FLASH TYPE" or "READ OR WRITE ERROR") Try resoldering your memory clear if you have problem with memory. Ok, Thanks
Goodluck then
mark2 9th Dec 2006 5:52 am
Hi sak_cheegii
Thats the first I have heard about memory being damaged. Resoldering sounds a bit drastic though?
kunal 9th Dec 2006 11:21 am
Captainzap, I just noticed that dump files are about 8MB each. Probably too big to be transferred by emails. Let me figure out were to share on web & I will let you know. Please suggest a good (& free)site for web storage & sharing if you know one.
kunal 9th Dec 2006 11:32 am
OK, here is the link to my web folder sharing. I have loaded one & in process of loading other two.
Hope it helps..
http://www.esnips.com/web/MP4Dumps
sorry, my bad!
