wilson 1gb digital mp4 player will not recharge
Old 2nd Dec 2006, 2:23 pm
hmm solved my own problem. i guess for this player i would need an ipod shuffle battery. thanks guys!
Old 2nd Dec 2006, 2:25 pm
well maybe not. it has no wires hanging out.
Old 2nd Dec 2006, 5:22 pm
Default Re: wilson 1gb digital mp4 player will not recharge
dopefisher11 , it all depends on your player's available space for the replacement battery. You need to measure the maximum length, width & thickness. Some sellers on eBay lists the ipod battery dimensions, but not sure if they are accurate. For my player, only the ipod shuffle fits.
The higher the mAh rating, the longer the battery lifespan, so go for a higher rating as possible. The only thing to look out for is the voltage rating, which is usually 3.7V, not much of a problem.
There is a post Here on using a nano battery. You might want to read it up.
Old 12th Dec 2006, 8:41 pm
Hey everyone update here! i successfully soldered on an ipod nano battery to my wilson 1gb digital mp4 player using a pencil soldering gun and a very tiny bit of rosin core solder. charging now, don't expect it to crap out this time. thanks for all your help. the only problem i have now is finding out what to do with my 512 mb player i ordered to replace this one!
Old 13th Dec 2006, 2:15 pm
well sh*t lol! again, i charged the battery for 2 hours with the power switch in the OFF postition by accident. is this what keeps killing my batteries? now the friggin battery won't charge again! or was the player unable to charge it in the first place? waaaaaaaahhhhhhhhhh
  #16 (permalink)
Old 13th Dec 2006, 3:17 pm
dopefisher11, That could be your problem, I have heard that recharging with the unit switched off can cause damage.
Recharge problem blackknife Support and How To 8 6th Sep 2007 7:13 am
[Solved] Desperately need help with battery recharge :( yenahs Support and How To 6 10th Aug 2007 6:11 am
Battery that not recharge wlazio2000 Support and How To 10 6th Jan 2007 1:18 am
my S1 Wilson mp4 Player 3.5.37 is dead. Sanja Dead Players 3 23rd Dec 2006 7:30 am
battery does not recharge gregoriocarbajal Support and How To 1 4th Nov 2006 5:04 pm
