Read/write error...check if device is connecting...
Old 5th Dec 2006, 8:31 am
Default Read/write error...check if device is connecting...
Read/write error...check if device is connecting...this is what i get when i try to reinstall my back-ed up dump.bin file. I firstly made a backup copy mf my FW...then i got a dead player...now i'm trying to reinstall dump.bin but i get the error message....what TO DO ?PLS REPLY THX!
Old 5th Dec 2006, 8:41 am
Default Re: Read/write error...check if device is connecting...
Pissy , i thought in your earlier post you mentioned you did not make a firmware backup?
But anyway, did you repair the firmware dump?
Also, try other versions of the MP3 Utilities.
Old 5th Dec 2006, 8:49 am
i just remembered i made a backup....i found it in the s1fwx folder.repair?how do u repair it and why ?
Old 5th Dec 2006, 11:22 am
any replyes....please....?
Old 5th Dec 2006, 2:06 pm
read all about it here http://www.mympxplayer.org/how-to-ex...tool-vt66.html
Old 5th Dec 2006, 4:44 pm
Pissy , do the method as broose had mentioned. Perform steps 1 to 15 in the guide. Then re-flash the repaired firmware dump into the player.
If you still get an error, try the following solutions:
1. try another USB cable
2. try other USB ports
3. try on another computer
4. uninstall and install other versions of MP3 Utilities.
" Read or write device information failed!" wlazio2000 Dead Players 11 4th Apr 2009 5:41 am
Error connecting to Rockchip MP4 iLuke Support and How To 0 4th Mar 2009 11:19 am
Help. Read or Write device information failed XoLoX Dead Players 2 20th Oct 2007 11:38 pm
"Read or Write device information failed" serp Dead Players 22 8th Aug 2007 12:57 am
Read or write device information failed!Please exit the... Pissy Dead Players 2 6th Dec 2006 3:44 pm
