2inch TFT, 1GB, BL-4C battery, CTW500
Old 7th Dec 2006, 2:36 pm
Default 2inch TFT, 1GB, BL-4C battery, CTW500
Hi there, i have successfully recovered my MP4, now i can connect it to pc in ADFU mode, but canīt find a working firmware.. The original was 9.0.43. There are many of this version (not for this player) but donīt work.
Could you send me a link with full f.w. or send me your own f.w.?
Thanks 8)
(the player: 2inch TFT, 1GB, BL-4C battery, cpu: CTW500, memory: Samsung K9L8G08UOM PCB0, image: my avatar. I think there is some "lucky draw action" on the web where it is called GLACIER)
Old 7th Dec 2006, 5:00 pm
Default Re: 2inch TFT, 1GB, BL-4C battery, CTW500
try this but only after you have used a full firmware www.brucedunton.com/stuff/dumpOsm.rar
Old 7th Dec 2006, 7:22 pm
h42k, Try loading one of the Full version 9.0.43 firmware in the download section. It will not recover your player but it will allow you to then load a dump file to your player. There is a dump from a similar player here:
http://www.mympxplayer.org/working-d...hip-df414.html
Old 8th Dec 2006, 2:48 am
Iīve allready tried this dump: http://www.mympxplayer.org/working-d...hip-df414.html
but without success. I load the dump into the player but then the player cannot conect to pc. But the dump seems to be the right one for my player??
Old 8th Dec 2006, 3:32 am
h42k, I have a 1.8 9.0.43 and I have 2 full version firmware for it they are both identical in every way except for 2 files within the firmware that have the same name but different checksums. One works on the player one kills it. These firmware onl;y need to have the slightest of differences and they do not work.
I know that there are other members with these players, have a look through the galley, a couple have posted pictures of their players there, I suggest you PM them ask if they would send you a copy of their firmware.
Try "TwoGame" and "Lejigabou" for starters.
Old 10th Dec 2006, 12:30 pm
Well guys, the problem was as you wrote. The version of MP3 Utilities. I used 4.05 and it never fixed my player. But today i recovered with 4.07 and it run with firmware for absolutely different player 8)
My advice: Donīt underestimate upgrading the Tools!
Thanks.
Looking for firmware: ctw500 9.0.43 Omega Dead Players 2 21st Sep 2007 4:27 am
ctw500 Rod Dead Players 2 11th Sep 2007 5:30 am
TFT LCD Screen 2inch replacement - UXCELL I-Palladium Gonso General Discussion - Uxcell.com 4 7th Apr 2007 4:40 am
CTW500 Rod Dead Players 0 28th Mar 2007 3:30 pm
any 2inch theme request arviverona Mods and Themes 2 4th Jan 2007 12:48 am
