..::Felix::..
You should only try the guide as a last ditch effort if the player is repaiable or replacable under warrenty then you should return it. I would only suggest the guide if you have no other options. |
Re: ADFU Mode...goes to 20% and freezes...help??
ok...although its gonna be my 4th player...
lets hope it wouldnt fuck up... lol!! :D :) |
I've got the same problem you have, and the answer is that you probably have the mp4 with the new chipset atj2091h and with the firmware 9.0.48.At the moment there`s no full firmware for this version.Let`s hope that it's not for long.
Cheers. |
could it be mp3 player utilities isnt compatible with 9.x.xx fw's?
| All times are GMT -7. The time now is 4:34 am. |
