ADFU Mode...goes to 20% and freezes...help??
Old 9th Dec 2006, 1:12 am
..::Felix::..
You should only try the guide as a last ditch effort if the player is repaiable or replacable under warrenty then you should return it. I would only suggest the guide if you have no other options.
Old 9th Dec 2006, 4:21 am
Default Re: ADFU Mode...goes to 20% and freezes...help??
ok...although its gonna be my 4th player...
lets hope it wouldnt fuck up...
lol!!
Old 9th Dec 2006, 5:04 am
I've got the same problem you have, and the answer is that you probably have the mp4 with the new chipset atj2091h and with the firmware 9.0.48.At the moment there`s no full firmware for this version.Let`s hope that it's not for long.
Cheers.
Old 9th Dec 2006, 5:22 am
could it be mp3 player utilities isnt compatible with 9.x.xx fw's?
Which one i will use to activate the ADFU mode? peterjohn1111 Dead Players 3 27th Mar 2009 11:38 pm
Can't get the player to adfu mode zrock Dead Players 7 15th Feb 2009 9:19 pm
How Can Update Mp3/Mp4 in Recovery Mode (ADFU Device Mode) oxygen0077 Firmware 1 28th Oct 2008 2:15 pm
Help with getting into adfu mode moneybankz Dead Players 7 25th Apr 2008 3:49 pm
Can't get into ADFU mode richard_s Dead Players 2 28th Nov 2006 8:00 am
