mp4 player needs help
Old 10th Dec 2006, 6:52 am
eDm eDm is offline
Default mp4 player needs help
Hi guys, i have mp4 player http://www.mp3-shop.lv/files/zc-45.jpg this one, with 1gb... i gave my mp4 player to my friend, he connected the mp4 player to pc, opened drive and deleted the main folder called 1.5.... now when i connect my mp4 player to pc it shows that the drive is full, all memory is used 1gb... and in the folder is 113 strange files called 5d1+┴.“¦* ; └dūü’jŌ{.Ūjp ; ╦č<žõ½n¢.▄▄Ļ ; no hidden files as well... all those files = 144 Kb, but it shows that there is no free space on the drive, all 1gb is used... i cant add nothing to my mp4 player, and cant delete nothing too... maybe i must do kind of a repair, or somthing... ??? all i can do is listen to the FM radio... :cry: (Sorry for my english ops: ) :roll:
Old 10th Dec 2006, 7:11 am
eDm, You may have a hacked memory chip. Try this process posted by "lattesurf" to reset the partition and format.
Old 10th Dec 2006, 7:16 am
eDm eDm is offline
Default Re: mp4 player needs help
Thank you verry much ! i will try... if somthing goes wrong i will post here...
Old 10th Dec 2006, 7:29 am
eDm eDm is offline
Nice, ive done it !! everything works great ! thank you tadad1 verry much !!! :wink:
