-   -   connecting problems/ please help (http://mympx.org/forum/dead-players/35368-connecting-problems-please-help.html)
mymp4 11th Dec 2006 4:07 pm
i have a wilson 1 gig ipod nano fake and when i connect my mp4 player to my computer usb it shows the connecting screen but it doesnt show the arrow when its connected what should i do please help
lattesurf 11th Dec 2006 5:52 pm
Re: connecting problems/ please help
mymp4 , while the player is connected to the computer via USB, are you able to see the player's drive on explorer? Also, are you able to copy/transfer files to and fro the player from the computer?
mymp4 12th Dec 2006 7:20 pm
i cant see the players drive on the explorer and i cant transfer songs either but on the litle screen it shows it connecting
lattesurf 12th Dec 2006 8:22 pm
mymp4 , try these few steps and see if they work.
1. Use all the other USB ports that your computer have.
2. Try connecting on another computer instead.
3. Try using another USB cable.
It seems to me that your USB cable might be faulty. And you player is only able to charge, but not connect to the computer.
mymp4 13th Dec 2006 7:26 pm
yea it is probably faulty i have to move it around just to charge show that orange light comes
