Really weird errors wth mp4 player,any help?
Old 19th Dec 2006, 12:15 pm
thanks.
Old 19th Dec 2006, 12:29 pm
ok driver installed flawlessly.used 3.5.35 again because i know that one works from earlier.still cant see it in explorer.going to try puting a dump in now.How do i know which is the right one? like, i figured id stay with the same number, 3.5.35, same screen size(medium 1.5) etc.how am i to know which could be right for me? if it helps i drop my chip no. off in just a sec
Old 19th Dec 2006, 12:41 pm
K9K8G08U0M is the chip number.
Old 19th Dec 2006, 2:28 pm
littledaz123, If the player is in ADFU mode and you have loaded a full version firmware the player should show in Windows. If it does not then I would suggest you try a few different full versions until it does. Then you can start using dump files. You are right to stick to the same version number and screen size but if you try them all and still have no luck then you could try 3.5.37 or even 3.2.16.
"How do you know which is the right one" it is all just trial and error without a backup of your original. I guess the right one will get your player going again.
Old 20th Dec 2006, 9:36 am
yeah i suppose.thanks for the help,anyway,much appreciated.happy christmas.
having weird issues with player cyfi Support and How To 1 4th Jan 2008 8:53 pm
help with some errors plz =( nervw Support and How To 3 11th Jul 2007 10:02 am
Format Errors when copying files to player mcdhonz Support and How To 1 8th Jul 2007 7:08 pm
Dead Player!!! Weird one though.... fizsle Dead Players 3 7th Jan 2007 8:12 pm
mp3/mp4 digital player weird files inside folders.HELP!! lledgarll Support and How To 3 22nd Nov 2006 10:17 pm
