Really weird errors wth mp4 player,any help?
Old 17th Dec 2006, 10:06 am
Default Really weird errors wth mp4 player,any help?
Hi,I have a black 1.5" 1gb mp4 nano clone.I flashed it with a firmware that was wrong and so i proceeded to the Dead player recovery guide.so i took the case off connected it to the pc, got it installed as a usb 2.0 adfu.However, i cant see the device in windows at all,whatsoever.no go.no removable disk icon.no nothing anyway continuing the story, my mp4 player was a version 3.5.37, and im sure it had file browsing,in the essence that you could see folders if you went onto a menu whilst it was in play mode.one other thing was im undecided as to whether the ACT version was 3.5.35 or 3.5.37,but i have a little feeling its 3.5.35. anyay, i try tadad's 3.5.37 firmware and a few others but there is errors.i try a 3.5.35 and, strangely enough it works.now, though,i am not allowed to complete the final step and flash a dump.bin file(i lost my old one,i made a backup once,before i reinstalled windows and linux)for some reason , the program always has an excuse and will only let me flash full 3.5.35' firmware to it.so basically i have a little piece of decorated plastic which has an amazing feat of showing you a blue screen after turning it on. please, if you have any ideas, respond.thanks.
Old 17th Dec 2006, 11:35 am
Que Que is offline
Default Re: Really weird errors wth mp4 player,any help?
Hi, check tadad1's posts in this topic:
tadad1 says format?
Old 17th Dec 2006, 11:50 am
the mp3 disk tool/manager gives me the error ''not detected removable disk! please check the disk connecting or rebbot system!''. so i cant format it.the upgrade tool finds it easy enough though.
Old 17th Dec 2006, 12:37 pm
littledaz123, Is the player visible in Explorer when you connect it? If so right click on it and format it with Windows. If it is not visible in Explorer but is detected by the Upgrade Tool then it is still in recovery mode as an ADFU Device in which case try and load another full version firmware to it.
Old 17th Dec 2006, 12:41 pm
the only full firmware that will give my player a blue screen is this one :
http://www.mympxplayer.org/full-vers...535-df435.html
is there a way to get a dump.bin for this?i would really appreciate the help.i can only load FULL firmwares onto my nano clone, and that is the only one that works.
if i try to load a dump then after putting this on it says(in the upgrade tool):
(if it reads the file)
Read or write device information failed! Please exit the program and see if the device is connecting!
any more ideas?
Old 17th Dec 2006, 12:49 pm
hang on.what if i cant see it in windows (tho having a full firmware on it)because its constantly staying on as an adfu.i cant figure out how to revert things back to mass sorage tough.i think updating the driver wont help much.i think its just gonna ask me to keep it as an ADFU.oh and by the way tadad, is that vista your using?
Old 17th Dec 2006, 1:19 pm
littledaz123, I do have the final release of Vista installed but in screenshots it is XP with WindowBlinds 5.
What version of MP3 Player Utilities are you using.
Old 18th Dec 2006, 9:15 am
ver, 3.15, 1.43 and 4.07.
Old 18th Dec 2006, 12:04 pm
i have an idea.whilkst installing the adfu driver it was missing afuud.sys or something like that.could you send me the file tadad?if its ok by you then ill give you my email adress to send it to.
Old 18th Dec 2006, 4:41 pm
littledaz123, There is an ADFU recovery driver included with every install of MP3 Player Utilities, in the RDiskUpdate\Driver folder. I have uploaded the drivers here:
http://uploaded.to/?id=9d913f
having weird issues with player cyfi Support and How To 1 4th Jan 2008 8:53 pm
help with some errors plz =( nervw Support and How To 3 11th Jul 2007 10:02 am
Format Errors when copying files to player mcdhonz Support and How To 1 8th Jul 2007 7:08 pm
Dead Player!!! Weird one though.... fizsle Dead Players 3 7th Jan 2007 8:12 pm
mp3/mp4 digital player weird files inside folders.HELP!! lledgarll Support and How To 3 22nd Nov 2006 10:17 pm
