why an ORIGINAL FIRMWARE 3.5.37 not start ????
hello,
on a dead player, i update with the original 3.5.37 complete firmware for recovery, but not runnning screen blue or black, (i upgrade with an dump 3.5.37 other (50 f/w tested) and it run ok ) but why firmware is not idem ? how i can passed to 9.0.43 or 3.5.38 firmware version on my player ? thanks a lot for responses ! h45-A-2 atj2085w samsung 619 (1go) 1.5 screen |
Thierryd , all these firmware version numbers are not accurate. The manufacturers do not follow proper versions control, and currently there are hundreds and even thousands of variants of the same firmware version number.
As long as your player is able to work, it does not matter which version you are using as they are basically all the same. Also, your processor is an ATJ2085W, and can only use the 3.5.3x series firmwares. |
Re: why an ORIGINAL FIRMWARE 3.5.37 not start ????
Oh ok thanks, but i have the original complete wilson 3.5.37 full but not run on my player atj2085w, what is reason and difference with constructor version (drivers is on full version too...) ? me i don't know
and version 3.5.38 not compatible with atj2085w ? thanks ! |
Thierryd, I have not seen a 3.5.38 firmware but usually the 3.5.XX series was ok for the ATJ2085 chip but that does not mean it will work with every Atj2085 player.
As lattesurf explained the firmware version numbering system is not very helpful. To explain if there are 500 factories making these MP4 Players and each factory is making 5 different model ATJ2085 players they will make a 3.5.37 firmware for each model they are producing so what you end up with is 2500 different 3.5.37 firmware for ATJ2085 players but they are each specific to the player that they were created for. |
| All times are GMT -7. The time now is 11:39 am. |
