NEDD FIRMWARE SAMSumg646
Old 20th Dec 2006, 5:56 pm
Default NEDD FIRMWARE SAMSumg646
1.5 lcd screen
Samsung 4gb player i need a firmware please.
Chip number=k9k8g08uoapcbo
THANK YOU
Old 20th Dec 2006, 6:02 pm
Alex, the K9K8G08UOA is only a 2GB chip so you have a hacked player. What is the serial number of the other smaller square chip?
Old 20th Dec 2006, 8:00 pm
Default Re: NEDD FIRMWARE SAMSumg646
It is four gb because i pu like 1.5 gb of music and i still head like 2.5 gb free.
I can hardly see my serial number but i'll try SR= ATJ2085H
CAN YOU HEME FIND THE FIRMWARE FOR IT IT IS SAMSUNG 646. PLEASE HELP ME FIND IT BECAUSE I NEED TO FIX IT PREATY BAD.
!!!!!!!!!THANKS!!!!!!!!!!!!!
Old 20th Dec 2006, 8:25 pm
Alex, despite the fact that it reads 4GB it is only 2GB. All 4GB no brand chinese players are fakes. 2GB is the most memory they can support.
http://www.mympxplayer.org/hotmale16...nz-vt2786.html
There is no way to tell which firmware is going to recover your player but the ATJ2085 is one of the most common chips used. The recovery process is just a matter of trial and error you need to try as many firmware as you can find that match your players screen size. Firmware versions 3.5.35 and 3.5.37 are most likely to be the best choice for the ATJ2085
If your player stops being recognised by your PC or the upgrade tool then you will have to follow the Dead Player Recovery Guide to reset the memory chip.
http://www.mympxplayer.org/dead-play...ide-vt567.html
Old 21st Dec 2006, 5:37 pm
Now my screen is black it doesn't work is that because my firmware is wrong. Can you suggest me a firmware please. Because i dont what i should use.
nedd an amv konverter whick can convert minimum in 128 to 96 Frederik Video related 1 4th Aug 2006 7:56 pm
