my 2" mp4 is not working..cannot write firmware for rec
Old 26th Dec 2006, 9:25 pm
Default my 2" mp4 is not working..cannot write firmware for rec
my mp4 player is a 2" fake sony...it went dead when i accidentally upgraded the wrong firmware..when im trying to recover it i went to the step by step til i reached the adfu device recognition but when im trying to recover my player using my backup f/w file..the MP3 player utlity says read and write error...my player is currently dead..need help with the pros...tnx :cry:
Old 26th Dec 2006, 9:26 pm
Default Re: my 2" mp4 is not working..cannot write firmware for
my f/w version is 9.0.43 wilson co.
Old 26th Dec 2006, 9:34 pm
arviverona, If the player is in ADFU recovery mode you need to load a full version firmware to your player your backup dump will not load untill a full version is loaded first.
If you have loaded a full version and your dump will not load be sure you repaired you backup after extraction or your player may need to be formatted to load the dump.
Old 26th Dec 2006, 9:42 pm
aah i see...i must get a full version..my chip is i think a samsung cjip and what kind of full version that i will use? my version is 9.0.43 wilson co. and 512 mega capacity...is it available or any alternatives? tnx for ur reply..tatad..i really need help
Old 26th Dec 2006, 10:32 pm
arviverona, Can you upload your firmware to www.uploaded.to and leave me a link so that I can download it. I will see what I can find for you.
Old 26th Dec 2006, 10:51 pm
i finally revived the plyer,,the computer recognized the device but the problem is i cannot see any image except a white background..and when i checked the firmware..there is a checksum error on the image files and when i checked it with the s1res 2.0 there is an error in the logo and no images on the other images like menu(in this menu images i can manage to import).. but still there are errors..but i will send you the firmware that revived my mp4 and my own backup dump...
the full version is the 9.0.43 2 inch firmware from the "full firmware section"
Old 26th Dec 2006, 11:03 pm
oh theres another problem a cannot import the ui30.res images..the s1res cannot import or preview the image
Old 26th Dec 2006, 11:13 pm
this is the firmware that revived my player
http://uploaded.to/?id=519fa8
and this is my old firmware dump
http://uploaded.to/?id=6f6cc6
i will send you after the extracted dump after reviving the player
p.s.
i tried to upload my old dump after reviving my player but the same happened..white screen..
if you need more info about the problem i am willing to share it to you as detailed as possible..
thank you for the support ops:
Old 26th Dec 2006, 11:14 pm
this is the dump after the recovery extracted by the swfx 3.0
http://uploaded.to/?id=8121b4
Old 26th Dec 2006, 11:22 pm
this is my mp3 player..exactly like this
i got this pic from bluemonk from the image gallery...
http://www.mympxplayer.org/image-full-asp126.html
" Read or write device information failed!" wlazio2000 Dead Players 11 4th Apr 2009 5:41 am
[solved]Can't write nothing and "not detected removable Karma Support and How To 0 17th Feb 2009 6:51 am
ANYKA D-M68 had stopped working goes "loading" praashekh Support and How To 2 11th Oct 2007 6:50 am
"Read or Write device information failed" serp Dead Players 22 8th Aug 2007 12:57 am
"The disk is write protected". What can i do? Cyen87 Dead Players 0 9th Mar 2007 9:24 pm
